245/40/19 All Around Handling?
Old 03-17-17, 02:06 PM
acnup00tl
acnup00tl's Avatar
Default 245/40/19 All Around Handling?
I'm looking to see who has the 245/40/19 all around set up on their AWD , and how the handling is? The stock tire 235/40 has very little to choose from.... Ive heard good things about the P7 but Im a huge Continental fan , and the DWS only comes in 245/40/19 .... Pics would help to of the all around set up...
Old 03-19-17, 03:12 PM
acnup00tl
acnup00tl's Avatar
WOW!!!! Not 1 person has 245/40 set up oral 4 corners? I guess I will just have to go with the oem setup , as I'm not willing to be the guinea pig...
Old 03-19-17, 05:14 PM
GSteve
GSteve's Avatar
I'm running 245/40/19 Pilot AS3 on my Lux awd. Can't compare to stock 19 size as I switched from 18s, but no complaints overall and obviously more responsive than the18s were. Main reason I went with 245 was limited selection in 235 as you've mentioned. I recommend going 245.
Old 03-19-17, 07:11 PM
acnup00tl
acnup00tl's Avatar
Steve,
Do you happen to have any pics of your setup? Most on the board have the staggered setup , and the 19s I got are all 19x8 ,so to have the all around set up seems to be pretty rare...
Thanks!!!
Old 03-20-17, 09:38 AM
k0kong
k0kong's Avatar
Originally Posted by acnup00tl
Steve,
Thanks!!!
I'm thinking of doing the same thing soon and the differences are pretty small, i don't know if it will translate to a visual difference unless you were looking really close.
235 has a 94mm section height
245 has a 98mm section height (+4mm) and (+10mm tire width).
Old 03-20-17, 12:20 PM
GSteve
GSteve's Avatar
Found these in my files from last year (I have Luxury wheels with winter tires on for 3 more weeks or so). The 245's are a little bit taller than the 235's which helps with the notorious wheel gap. Every bit helps given that I don't want to lower it
Old 03-20-17, 02:40 PM
acnup00tl
acnup00tl's Avatar
Steve,
You just sold me on the 245s!!!!.... I'm gonna order the Tires next week... Anxiously looking forward to seeing the F Sport wheels on the car... Thanks for the pics!!!
Old 03-20-17, 02:43 PM
acnup00tl
acnup00tl's Avatar
The numbers you posted don't seem to equate to much difference so the 245s are a no brainer given the lack of options for the stock tire...
Old 03-21-17, 07:15 AM
JWBlakk
JWBlakk's Avatar
I had the 245/40/19's all the way around before I went staggered on my AWD. The handling was good for me but mine came with them when I bought the car so I don't have any experience to compare to.
Old 03-21-17, 07:59 PM
acnup00tl
acnup00tl's Avatar
Thanks for the post!!! I'm now sold on the 245s..
Old 03-21-17, 08:19 PM
gadgeeets
gadgeeets's Avatar
I'm in the same boat and was looking at the same tires , when I do need tires im getting the conti's 245 I had both tires and I can say the p7 are nice as well
Old 03-22-17, 06:59 AM
e60bmw
e60bmw's Avatar
I don't have 19's but I've been happy with my Yokohama YK740's, they are 235/45. I don't know if its the tires or the awd but when I take a pretty quick turn the car just completely sticks to the road. Still getting used to how I can push it with the setup, other cars I wouldn't have trusted making turns at the speeds I've tried, its probably more having the AWD.
Old 03-22-17, 02:23 PM
acnup00tl
acnup00tl's Avatar
I wouldn't mind the 235s but there aren't many to choose from , where as the 245 has several ..
Old 03-23-17, 11:07 AM
conclevage
conclevage's Avatar
If 245s work on AWD with factory stance then I'm all in...agreed that there's slim pickings for the 235s.
Old 04-05-17, 08:51 PM
kitra
kitra's Avatar
Has anyone checked their speedometer and odometer error with the 245 series tires on an AWD? Just curious. OK, looked up on google and it appears to be 1.2% error. Not bad. Site says if the speedometer shows 100 MPH, you are doing 101.2. That sound right?
Quick Reply: 245/40/19 All Around Handling?
