Lexus Laser Projector door Light Issuie.
I'm referring to the projector that puts the lexus logo on the ground when you open the door.
I bough a set of 4 on eBay for $45. The lens in the projector rattles when I shake it. I don't want to put something that rattles in my hand into the door.
Did anyone else have this rattle when they bought there projector? Was it an issue once in the door?
If your doesn't rattle what seller/manufacture did you buy it from?
Thanks.
Thanks.
peasodos (03-08-17)
That happens to be the seller I bought from and returning. If you shake the product you hear the rattle. It turns out the lens in the projector is loose, causing the noise. I guess mine must just be defective or a bad batch.
Pure white for me, thought it would look best with liquid platinum. I believe the color logo chips fade after awhile as they offer one free replacement with the original purchase.
Thanks.
Thanks.
Can you not determine what is loose that is creating the rattle?
Yeah you must have received a defective one. Im sure he will switch it out with a good one. I haven't had any issues with mines and my friend has them in his LS with no issues as well.
I bought mine from Black Menba, only cost $18. Total 4 lights, but only installed on front doors due to the rear door angle for the projection. I noticed mine rattled, I read on other posts where they say the lens can rotate the image over time with door slams,etc. Some people used super glue, I was too lazy and just popped them in, no noticeable rattle while driving. I figure I have two other ones I can put in if the lens rotates. I like the projection on the ground, but miss the light around the lens itself.
Lyndsay155
RC - 1st Gen (2015-present)
02-21-18 07:20 AM
