Differetn tire sizes on stock wheels
I have 2013 f-sport awd 350GS with stock 19" wheels which wear 235/40/R19 tires (I still have original Bridgestone turanza el400). Because of pot holes in sfbay area one of front tires cracked near rim and I need to replaces tires now.
So, I guess I have to replace either all 4 tires or 2 fronts? I've read that 245/40/R19 can be used on stock rim and these usually have higher weight rating (750kg vs 710kg, e.g. hopefully they will stand better against pot holes).
Should I put on 245/40/R19 in front and keep old 235 in the back, should I change all four to 245 or should I put 235?
I'm a careful driver and I don't push my car, so I'm mainly interested in durable less noisy tires. These based on price or ratings are the once I'm considering in the order of preference:
Yokohama ADVAN Sport A/S $166
Pirelli Cinturato P7 All Season Plus $216
Michelin Primacy MXM4 $221
Yokohamas are first simply because they have good rating and are $50 cheaper. My car is still on lease, it expires in a few months. I'll keep the car, but then most likely I'll sell it next summer.
changing to 245 won't make a lot of difference in protecting from pot holes, and it'll actually make more tire noise cause theres more rubber on the road. Since you're a careful driver and don't push the car, why not change to change to 18 inch rims and put 235/45/18? It'll have more protection from pot holes, less noisier ride, and more comfort!!!
On an AWD, you'd want all 4 tire sizes the same. Switching to a 245/40 over a 235/40 won't have much difference when it comes to withstanding a rim-breaking pothole, in my opinion. Yeah the tire will cover a tiny bit more surface area, but I doubt there'd be any noticeable difference in protection.
I know the Bay Area potholes extremely well... cracked a rim on my previous car with 18s and a 235/45s. Our potholes are unforgiving
I thought there is better protection not because there is 10mm width increase, but because these are usually rated for higher weight bering capacity.
I didn't know that wider tires would be noisier, so I stick to 235s then.
I wouldn't switch to 18, since I'd need to change rims, and I don't want to mess with that: I really like stock rims and overall look, don't want to change that.
Any suggestions regarding tires?
I don't get this: how about these douchebags that collect taxes: do they fly helicopters? Or they take caltrain only and never meet these holes?!
I've driven past that spot and everytime I see traffic slowing down there
Aside from avoiding potholes altogether, thicker sidewalls are your best protection (18" wheels). The ever-so-slight increase in sidewall from a 245 tire isn't appreciable. I'm not sure if a higher load rating will really make the tire withstand potholes better, although it's a logical thought.
On tires, I don't have experience with those specific Yoko's but my experience with 2 other Yoko tires on another car was sub-par. They were well-rated tires and I didn't care for them, especially because both sets had trouble balancing. The Pirelli you listed is popular on our car and I've known folks who liked their Michelin MXM4's.
Hit a bad train tracks the other night and my car felt like bottoming out and falling apart. The noise was loud as hell but when I check my undercarriage, not a single scratch on it and nothing bent.
I have the upsized set, 245 fronts and 275 rears.
Can't speak for the Yokes, but I've had the Michelin's on another car and liked them. But I highly recommend the P7's on this car. I switched to them early on with my GS (had new, but crappy tires on when I bought it) and it was like driving a different car. So quiet.....
Same tires as mine.
Slightly off-topic, but you can trying getting Caltrans to reimburse for pot hole damage:
http://www.dot.ca.gov/damageclaims.html
Story: http://www.sfgate.com/bayarea/articl...p-10881594.php
