Tire Pressure Monitor Not Displaying Pressure
Old 02-28-17, 07:56 PM
aachowhan
aachowhan's Avatar
Default Tire Pressure Monitor Not Displaying Pressure
I have a 2013 GS and the tire pressure light is on. When I switch to the tire pressure menu in the dash all I get is "--" for the read out for all the tires.
Anyone know what is going on? How do you reset it? I found the button but what is the procedure? I held it down and it flashed a serveral times but nothing happened after that. It came back on and stayed on with no read out.
Old 02-28-17, 09:26 PM
spoogenet
spoogenet's Avatar
Any similarity to this thread?
https://www.clublexus.com/forums/gs-...i-on-dash.html
Old 03-01-17, 05:50 AM
aachowhan
aachowhan's Avatar
Originally Posted by spoogenet
I guess that is the issue. Looks like I'll just have to take it to a tire shop or Lexus and try to get them to cover it under warranty but that might be a long shot.
Old 03-01-17, 08:59 PM
kamskeez
kamskeez's Avatar
If you recently had the tires changed, make sure they didn't break the TPMS sensor.
Those sensors can break inside your tire as well, if you hit a huge pothole or something. They batteries has a lifespan of around 7-10 years or so as well. Could be a host of things, but best thing to do is to try and get the sensors read somewhere and see if the scanner picks up the code. If so, might just need a quick reprogram.
Old 03-01-17, 09:20 PM
richard203
richard203's Avatar
flashing tpms light mean your tpms sensor not working.
Old 03-02-17, 06:31 PM
aachowhan
aachowhan's Avatar
Yeah I'm planning to head to a tire shop and have them check it out. I found some sensors on ebay for 17 bucks. Not to bad I guess.
Old 03-03-17, 05:01 AM
RA051823
RA051823's Avatar
Unfortunately you need a computer to check sensor operation and to program the new sensor ID's into the car. I miss the days when all that was needed was a magnet to program your TPMS sensors to the car, but like most car companies they profit on complexity.
Old 11-03-23, 11:04 AM
Saifali666
4th Gear
Saifali666's Avatar
I have the exact car year and make and model took it to discount tire they told me batteries are low and the only way they can change the battery will be my braking something which then be better off changing the whole sensor it cost me 60 dollars each with putting the on hope it helped
Old 11-06-23, 02:35 PM
carlos3366
carlos3366's Avatar
Default I suggest
Buying Lexus sensors.
Old 11-06-23, 02:38 PM
carlos3366
carlos3366's Avatar
Default I suggest
bclexus
04-27-21 06:19 PM
tus
Hybrid Technology
05-15-17 07:28 AM
peterrx
RX - 3rd Gen (2010-2015)
04-02-16 06:35 PM
TXFM
02-09-07 06:46 AM
AZHenry
12-08-06 09:33 AM
Quick Reply: Tire Pressure Monitor Not Displaying Pressure
