Will these wheels fit?
Currently on RSR Super Downs and need help
(20x11"/5x114.3mm, +25mm offset) Rear or (20x11"/5x114.3mm, +52mm offset)
(20x9"/5x114.3mm, +35mm offset) Front
Front is fine, you may rub depending on what tire size you go with.
For the rear +52 is too conservative, the wheel is gonna look slightly sunk in compared to the front, and the +25 may require some fender modding or some camber to fit right. Again tire sizing may cause issues too
nasc300
Wheels, Tires & Brakes Forum
16
08-17-05 05:51 AM
