Brake Rotors and Pads
Old 08-18-16, 08:27 PM
Nasrul3698
Nasrul3698's Avatar
Default Brake Rotors and Pads
Searching for aftermarket Rotors and Pads that can replace the stock ones in the 2013 Lexus GS 350 F Sport RWD. Stock Rotors are getting thinner and here in Malaysia it costs RM 4000 (U$D 1,000) to replace only ONE rotor at Lexus. Might as well spend it on aftermarket Rotors and Pads.
Anybody here can help me with this? /:
Old 08-18-16, 09:53 PM
CottageChz
CottageChz's Avatar
I have replaced my rear rotors and pads. I used OEM rotors and Akebono pads. Very satisfied with the results. Sorry I cannot recommend any non-OEM rotors for you.
Old 08-18-16, 11:55 PM
Dallasguy1
Dallasguy1's Avatar
U can find bunch of them on Us eBay see if they ship overseas will cost you a lot less then going oem.
Old 08-19-16, 09:20 AM
Nasrul3698
Nasrul3698's Avatar
Will try and search harder for them then
Old 08-19-16, 09:41 AM
AJLex19
AJLex19's Avatar
Received 1,128 Likes on 837 Posts
Replaced my rear brakes and rotors on my '13 AWD. Used ATE PremiumOne Rotors with Akebono Brake pads. I'm definitely pleased with the performance of this combination of aftermarket brakes/rotors. My mechanic has also always recommended Centric brand aftermarket rotors.
Here's a thread showing the ATE PremiumOne Rotors on my GS: https://www.clublexus.com/forums/gs-...-4k-miles.html
Another helpful thread about Centric Rotors: https://www.clublexus.com/forums/gs-...wd-gs350f.html
Old 08-19-16, 07:13 PM
protocol71
protocol71's Avatar
Ajlex, those rotors are awd and are not 2 piece rotors which is what the rwd version requires. This is also why you cant find any aftermarket versions.
You have to bite the bullet and pay lexus. I found mine for 225/side online and both do have different part#s so make sure to order the correct ones. I also used the ceramic akebonos with the original lexus backplates to eliminate unwanted squealing that may occur with the akebono plates.
Installation is a snap. Banged mine out in 90min with cleanup.
Old 08-21-16, 09:18 AM
Nasrul3698
Nasrul3698's Avatar
My only other option is StopTech then, but they come with the callipers /:
Old 08-22-16, 08:50 AM
Lakersfan
Lakersfan's Avatar
if they are charging you $1000 per rotor, u may as well go with a BBK
dang and i thought $250 per rotor was expensive.......
Old 08-22-16, 09:53 AM
GregCanada
GregCanada's Avatar
Order them from a US dealer and pay shipping? You should be able to get both rotors with shipping and taxes for under 1k.
Old 08-22-16, 06:43 PM
Nasrul3698
Nasrul3698's Avatar
Found these EBC RK series rotors selling for about $630 (inc.shipping) for all 4 on eBay. Can't find any slotted discs that can fit the front brakes on the F Sport RWD
skottydznt
Suspension and Brakes
12
04-08-17 02:05 PM
aumate
RX - 3rd Gen (2010-2015)
12-07-16 10:42 AM
Fife
11-09-14 05:33 AM
saelee39
12-20-09 08:09 PM
LEXITT
18
03-18-06 05:12 AM
Quick Reply: Brake Rotors and Pads
