Problem with 2016 fsport fog lights from nigel
Old 07-21-16, 01:51 PM
silvaIS
silvaIS's Avatar
Default Problem with 2016 fsport fog lights from nigel
I tried to install the fog lights but the driver side has the windshield washer fluid container blocking access for the fog light to sit properly. Has anyone fixed this some how it figured out some other solution
Passenger side worked perfectly fine
Old 07-21-16, 04:27 PM
SNiiP3R
SNiiP3R's Avatar
JDM spec cars must have a different shape fluid container or it may not even be there at all.
Old 07-21-16, 04:37 PM
gsfcrafted
gsfcrafted's Avatar
I have a 2015 GS Fsport and encountered the same issue. Apparently, Lexus for some reason used a larger fluid container from 2015 on. I contacted the fog light manufacturer (iJDMToy) and they said that I need to swap out the fluid container from a 2013-14 model for me to install the fog light.
Looks like no fog light for me too!
Old 07-21-16, 08:50 PM
silvaIS
silvaIS's Avatar
well that doesn't sound too bad...how much can this new piece cost? and why doesn't nigel sell it with the kit or atleast offer it
Old 07-21-16, 09:12 PM
biggame
biggame's Avatar
Here is the replacement washer bottle part #85315-30460
Old 07-22-16, 05:27 AM
silvaIS
silvaIS's Avatar
this part doesn't seem right. its the same item we have in our cars
Old 07-22-16, 06:19 AM
Nixus
Nixus's Avatar
http://jp-carparts.com/lexus/partlis...ype=5&fig=8503
Old 07-22-16, 07:59 AM
biggame
biggame's Avatar
https://www.clublexus.com/forums/gs-...-wheels-3.html
Old 07-22-16, 12:06 PM
mrpartsman
mrpartsman's Avatar
Welcome to my world, he should have told you that I bet you also u were missing screws and is ur wiring short also. so the part number the Biggame gave u is correct, I came up with that I have it on my car , do not look and the online pics they are all wrong just go to dealer and order that 85315-30460, and get 8 extra screws also while ur at it so u can mount the lights correctly. and if u need help let me know I went threw that , it took me over 2 weeks 2 finish because Mr.nigel didn't know anything about it, and I had to ruin my factory reservoir. And by the way did u take the bumper off to mount it or u did it on the car.
BlueByYou (01-04-23)
Old 07-22-16, 12:18 PM
silvaIS
silvaIS's Avatar
this is awesome thank you so much!!!! we should make this a sticky!
Old 07-22-16, 12:19 PM
silvaIS
silvaIS's Avatar
I wasn't doing it my self, so I paid a guy who charged $50 and then I had to put everything back cause we couldn't finish the job..he did peel the bumper a bit from botton to get in there. but I guess now to change the reservoir we will need to take it off.
Old 07-22-16, 01:01 PM
mrpartsman
mrpartsman's Avatar
Noooo, there is no way u can get to the screws with out taking the bumper out, and also u have to make sure u get new screws like I said, u cant just put any screw in it, u will crack it, its cheap at the dealer 90cents ea. do the job once and do it right, don't ruin the car, trust me i went threw it already , its up to u. Like I said u need help just ask me.
Old 07-22-16, 01:14 PM
jjashaa
jjashaa's Avatar
this is weird.. i feel like people are getting different results with different fogs...
my OEM LED fog lights i purchased from japan had no issues with mounting against the washer res.
Old 07-22-16, 01:16 PM
ULTiMaX99
ULTiMaX99's Avatar
where do you get the longer wiring harness from?
Old 07-22-16, 01:53 PM
mrpartsman
mrpartsman's Avatar
well u have 15 correct, ours is 16 thats why.
Quick Reply: Problem with 2016 fsport fog lights from nigel
