Using the physical Key to turn on engine
Hi, how do you use the metal slide out key to start the engine if the battery dies? just curious. I don't see a slot to put in a key.
if the battery on the key fob dies, can you still use the Engine start push button as long as the key fob is in the car??
Michaelb2 (06-12-22)
You hold the fob close to the start button and it will start.
The following 3 users liked this post by Flying3:
Flying3 knows what he is talking about. I first verified that my car (2015 GS 350 F Sport) would not start with the key fobs in the house. I then took 1 key fob to the garage and took the battery out of it and left it all on the work bench. Attempted to the start the car with the same result (no start) as the key fobs being in the house. I then took the battery-less key fob into the car and it would start, but only if the key fob was virtually touching the start/stop button. So, even without a battery at all, it will still start. Well done Flying3; thanks for the education. Tomorrow morning, I’ll verify my wife’s car (2015 IS350 C) operates the same way, then I’ll show her what a clever husband she has. Thanks Flying3 for making me look good!
The following 3 users liked this post by TeamBone6:
The following 3 users liked this post by Mike728:
ECL (06-13-22)
Metal slide out key is for opening the driver side door and trunk. And as a tool to release the shift lever lock so you can move it to neutral in case you want to tow it.
https://secure.drivers.lexus.com/lex...nual-search.do
The only times I see my manuals is the day I got the car and the day I trade in the car. The rest I just search online.
And for locking the glovebox I assume? You take the physical key and leave the fob with the parking attendant. Although I've never noticed if our glovebox supports this.
