F-Sport AWD Rotors
Old 05-09-16, 05:24 AM
Igor911
Igor911's Avatar
Default F-Sport AWD Rotors
Has anyone come across any aftermarket options for rotors on the AWD model? I cannot seem to find anything besides pads...
In desperate need of a rear set and it seems the dealer may be the only option...
Thanks in advance!
Old 05-09-16, 07:30 AM
rld14
rld14's Avatar
rockauto.com
Aftermarket, $32 or so each. Now, are they any good? That I can't tell you.
Old 05-09-16, 07:45 AM
sonyfan
sonyfan's Avatar
Go with Stop Tech. You can order it from rockauto.com
Old 05-09-16, 07:47 AM
Igor911
Igor911's Avatar
Doesn't look like Stop Tech makes them for the GS350 F AWD.
The OEM part is 42431-30310
Old 05-09-16, 07:50 AM
sonyfan
sonyfan's Avatar
It's under Centric brand
Old 05-09-16, 07:52 AM
sonyfan
sonyfan's Avatar
Make sure to Google rockauto discount for additional savings 😉
Old 05-09-16, 10:11 AM
GregCanada
GregCanada's Avatar
I bought the OEM rotors and pads, just did mine 2 weeks ago. The price was surprisingly low, cheaper than i could get aftermarket for, and of course they fit perfectly.
Old 05-09-16, 11:01 AM
Igor911
Igor911's Avatar
I think my dealer parts quoted me $117 (ea) Front and $147 (ea) Rear
Old 05-09-16, 11:32 AM
GregCanada
GregCanada's Avatar
Wow, i paid 120 each for rotors, canadian. pads were 100. Figured it would be 25-30% less in the states (going rate).
Old 05-09-16, 11:33 AM
Igor911
Igor911's Avatar
That was also the cheapest quote in my region... Thus, why I'm looking for an aftermarket set
Old 05-09-16, 11:58 AM
rld14
rld14's Avatar
GS F-Sport AWD uses regular rotors, only the RWD F-Sport uses unique front rotors.
Them be the pricey ones... they're 2 piece.
Old 05-11-16, 07:18 AM
Igor911
Igor911's Avatar
So I ended up getting a special order of Wearever rotors from Advance Auto (left) and I purchased an OEM set from Lexus (right).
The advance rotors were $35 each and Lexus was $147. I ended up staying with the Lexus ones due to a lot of bad reviews online with respect to early warping and rusting around the hub area on the advance rotors.
<br >
Old 05-11-16, 07:25 AM
SRC350F
SRC350F's Avatar
How many miles did you have on your old rotors before you needed new ones?
Old 05-11-16, 07:27 AM
Igor911
Igor911's Avatar
It wasn't so much the miles, the real problem was that my rear pads wore down so much that they actually started to damage the rotors. Careless mishap on my part, so I had no choice but to replace them.
Old 05-11-16, 07:36 AM
GregCanada
GregCanada's Avatar
Mine lasted 40,000 miles. they were half-rusted out on the inside (outside was fine though?)
Driver side pad did not wear evenly, and one side was 40%, other side was almost 0%. Passenger side it wore evenly, and pads were are 20% each.
Quick Reply: F-Sport AWD Rotors
