Bayson "L" Lip & LED Fog Installed!!
It was my birthday this past weekend so I got some cool stuff and installed them.
The fogs was kind of a pain to install. The wire harness that came with the kit seems to be a universal one which was not even long enough to stretch from one fog to the other side. I had to extend the wires to make it work. I tapped them into the gauge light which gave me power as soon as the car ACC is on and I can turn them off with the switch. I would say the harness part was to fish the switch through the firewall to connect to the harness. Ended up mounting mine where the parking brake is since I did not want to drill into any panels. This was the cleanest place I could find.
The Bayson Lip was pretty easy to install. You WILL have to put about 7-8 screws on the bottom of your bumper. The material is very flexible so it will "droop" if you don't have enough screws. instillation was pretty straight forward. I opted to wrap mine in 4D carbon fiber vinyl to match my mid section. Turned out great. Only issue with this was that the material did like to stick to the wrap. It was a bit tricky.
Great job - looks great! I feel like the f sport versions should have come just like this from the factory: with the blacked-out mid-front bumper, the LED fogs and a similar lip as part of the standard f-sport pkg.
Thanks. That is the look I am going for. Noting too crazy. Just doing mods that should of came from the factory with the F-Sports.
100% no, those vinyl wraps are hideous. there was a gs i was going to buy but someone vinyl wrapped it and did some other monkey mods to it. so annoying.
mrkwinning, got my bayson lip today. did you pre-drill the holes in the bumper first? also, did you use and retaining clips for the screws or just screwed them in? thanks.
They came with the self tapping screws. No need to drill holes since the self tap are sharp and small enough to make a pilot hole as it touches the bumper. I really didn't want any holes in the bumper but with the Bayson Lip being so flexible, you will need to add about 6-8 screws.
