F-Sport fog light retrofit started...
Old 04-08-16, 11:45 AM
  #31
mrkwinning
mrkwinning's Avatar
Originally Posted by mx5mike
I installed my LED Fogs last night. Had to extend the IJDM wiring harness to the drivers side fog light and I also didn't run my signal wire to the Parking lights. I ran the signal Wire to the Guage Fuse in the drivers side engine fuse panel with a add a circuit. this is a 5 amp factory fuse that is only powered on when the car ignition is on so I can use the fogs independent of the headlights. running the wire through the firewall was easy enough with a metal coat hanger and electrical tape. I am extremely happy with the light output and beam pattern. nice and crisp. and I didn't have any issue the the washer bottle in my 15 other than its a tight fit between the back of the fog light housing and washer bottle. There are no gaps around the lights and the garnish trim and everything fits and works like a charm. I mounted the fog light switch to the left of the steering wheel below the odometer gauge illumination controls with the supplied double sticky back tape.
What did you mean by "fuse panel with a dd a circuit"?
Old 09-27-16, 04:54 PM
  #32
LatinLS430
LatinLS430's Avatar
I want to add fogs with yellow film to my F Sport. Where can I get the shrouds for the fog lights? I got the Valeo part numbers for the fogs.
Old 09-27-16, 05:25 PM
  #33
ricam78
ricam78's Avatar
Check with Nigel-jdmparts info@nigel-jdmparts.com
If no luck let me know as i have the part numbers.
Old 09-28-16, 06:31 PM
  #34
LatinLS430
LatinLS430's Avatar
Thanks!
​​​​​​​I just send them an email. Hopefully they will reply.
Old 09-29-16, 08:08 AM
  #35
LatinLS430
LatinLS430's Avatar
They replied and here's the link for all the options they have.
http://www.nigel-jdmparts.com/index....product_id=161
Old 09-29-16, 08:48 PM
  #36
Nigel-JDMParts
Nigel-JDMParts's Avatar
thank you
Feel free to email us if you need anything, we have these fog light set in stock and ready to ship.
Old 10-04-16, 04:11 PM
  #37
LatinLS430
LatinLS430's Avatar
Do you think I can do what you did with your wire with these fogs:
Where did you get the coaxial cable?
Old 03-22-17, 10:55 AM
  #38
elidari
elidari's Avatar
Hi guys does anybody know how to turn on the running light without starting the engine and put it in drive thanks
Old 03-22-17, 10:59 AM
  #39
ricam78
ricam78's Avatar
You mean the LED strips in the headlights?
You can put the key into ACC mode....then if you want them brighter turn the light stalk to the first position
elidari (03-22-17)
Old 02-11-19, 06:19 AM
  #40
ricam78
ricam78's Avatar
A little update. The standard bulbs ended up putting dark spots on my Lamin X over time. After going through 2 sets (warrantied via Lamin X) I switched to these bulbs and have been very happy. They generate basically no heat
Amazon Amazon
Old 03-24-19, 09:28 AM
  #41
baconRx
baconRx's Avatar
Anyone know if there are better quality LED lamp housings over OEM? trying to figure out if I want OEM or just a cheap ebay one if OEM isn't that great this is for a 2018
Old 01-22-20, 08:51 PM
  #42
Neophyte2b
Neophyte2b's Avatar
OK, all done. I didn't want to tap or destroy any factory wiring in case, so here is what I did for my trigger wire to work with parking lights. It is actually a strand of wire from a coaxial cable that I clipped and soldered to the multistrand trigger wire then heatshrinked. I also pushed the wire into the weatherproof boot a tad more but forgot a pic so it's actually fully inside the boot now. ( Pics are backwards sorry )
What's that white rectangular box with the wires called, and where does it originate from? How would I access that?
On another note, what would I do differently if I would like the fog lights to turn on with the headlights instead of the DRL? Thanks.
Old 01-22-20, 08:55 PM
  #43
Neophyte2b
Neophyte2b's Avatar
Would you be to take a picture of where the Gauge Fuse is and also what you did exactly with the wires? I'm new at this, so the more pictures, the better. Thanks.
Old 01-24-20, 05:41 PM
  #44
nitrotang
nitrotang's Avatar
I'm assuming that plugging in the wires into that 24-pin connector is just for the relay portion of your fogs correct? You still had to hook the fog lights to the battery directly for power?
Old 01-28-20, 01:18 PM
  #45
Neophyte2b
Neophyte2b's Avatar
Where did you get the yellow fogs for your '06? Did you install Lamin-X over the Morimotos?
Quick Reply: F-Sport fog light retrofit started...
