Foglights on 2016 F-Sport
Old 02-22-16, 03:09 AM
bigblack06
bigblack06's Avatar
Default Foglights on 2016 F-Sport
Does anyone have any info on the fog lights and how to upgrade them. I have not seen any members do it yet so I would like to get some info on it.
Old 02-22-16, 05:21 AM
kawaiiGS
kawaiiGS's Avatar
Its probably the same install steps as MY2013-15. If Japan has fogs for their '16 FSport, chances are it can be done.. Provided you can aquire the foglight covers for them.
Old 02-22-16, 07:55 AM
dman3626
dman3626's Avatar
Yeah the only issue is that bumper redesign leaves very little room for fogs on the 2016 F Sport. I could see them maybe fitting some vertical led lighting, not sure about fogs.
Old 02-22-16, 08:27 AM
bigblack06
bigblack06's Avatar
Yes it is offered in Japan and Europe again. I need to find out what LED housing from Lexus I can get as well as the garnish.
Old 02-25-16, 04:24 AM
kawaiiGS
kawaiiGS's Avatar
Most likely.. You could grap the already existing housing offered for base MY2016 and order the harnesses for them.. Have you taken off the stock Garnish to see if there might be mounting points for a foglight?
That could give you some insight on whether anything would fit.
Old 04-12-16, 08:26 PM
mrpartsman
mrpartsman's Avatar
well i have the 2016 and I just started doing the fog lights and I ordered everything from Nigel,so I hot the LED fogs and the Bezels and the wiring harness, so the problem I have is the washer fluid reservoir is on the way , so I have to modify it and the sucky think about it there is no instructions in it.
Old 07-21-16, 04:20 PM
silvaIS
silvaIS's Avatar
Originally Posted by mrpartsman
well i have the 2016 and i just started doing the fog lights and i ordered everything from nigel,so i hot the led fogs and the bezels and the wiring harness, so the problem i have is the washer fluid reservoir is on the way , so i have to modify it and the sucky think about it there is no instructions in it.
what did you do to figure a solution for the fluid reservoir
marsmango
12-22-17 09:30 AM
yardie876
06-24-14 03:54 PM
LGSFS2012
08-23-12 09:59 PM
LexusNN
06-07-12 07:20 PM
Quick Reply: Foglights on 2016 F-Sport
