F Sport RWD Tire options
Old 02-10-16, 12:36 PM
bigbwb
bigbwb's Avatar
Default F Sport RWD Tire options
My wifes GS350 F Sport RWD is approaching 50k miles and the stock staggered setup is getting quite worn. Living in WI, I swap out tires/wheels in the winter, so no need for all seasons.
Question is this, the summer set are staggered and based on what i can find on TireRack, the options are 1 of 2 Both of which are fairly soft high performance rubber which the wife does NOT require. What other options or alternate sizes might work? I am looking for a tire with better wear/longevity rather than outright grip.
Any input would be helpful. I have a good month or so before I need to swap out the winter set.
Thanks!
Brandon
Old 02-10-16, 01:00 PM
Bartman619
Bartman619's Avatar
Try searching these sizes....245/40/19 Front and 275/35/19 Rear. These tires are only 10mm wider than the original size and other GS owners in the forum are also using these sizes. It will also give you more Tire Brand selections in Tirerack.com and other tire stores.
Old 02-10-16, 02:58 PM
Davenlei
Davenlei's Avatar
How much does that change the diameter of the tire (how far off will the speedometer be)?
Old 02-10-16, 03:45 PM
Bartman619
Bartman619's Avatar
Diameter doesn't change only the width of the tire, increased by 10mm. I really don't thing speedo will be affected at all.
Old 02-10-16, 03:53 PM
Davenlei
Davenlei's Avatar
Correct me if I am wrong but I thought there was a relationship between tire width and sidewall height so a 245 tire would have a slightly taller sidewall than a 235 tire even though both are rated as 40 series. If the sidewalk is taller (considering the same size rim), then the rotational diameter will be different and cause the speedo to be off slightly.
Old 02-10-16, 03:58 PM
GSHLNMTR
GSHLNMTR's Avatar
I calculated it when I got my F-Sport RWD back in November and the speedometer should be off by slightly less than 1 MPH.
https://tiresize.com/speedometer-calibration/
When the OEM Bridgestones wear out I will likely get the wider tires so that I can get all seasons. We just had the second time this winter here in Atlanta/North Georgia when I had to leave it parked, thanks to frozen precipitation on the roads. Not fun at all
Old 02-10-16, 04:23 PM
supra725
supra725's Avatar
I been thinking about it too..
I have 235/40/19 and 265/34/19 in the back.. with that choice, there aren't many.
currently i have Dunlops in mine but i want to switch over to pilot super sport's when the dunlop wear out..
does anyone have the 245's and 275's pictures? does it stick out anymore in the back?
Old 02-10-16, 04:25 PM
Bartman619
Bartman619's Avatar
Here you go.
https://www.clublexus.com/forums/gs-...-s-please.html
Old 02-10-16, 05:41 PM
bigbwb
bigbwb's Avatar
Thank you! Quite a few options in this size! Might even consider the all season BFG g force comp 2 AS. Awesome ratings!
Old 02-10-16, 07:19 PM
Afrosheen
Afrosheen's Avatar
I love my Pilot Sports but I live in Texas, so all seasons aren't really a concern.
Old 02-11-16, 07:42 AM
Davenlei
Davenlei's Avatar
Hmmm, from those pics it looks like the front sidewalls are completely flat and not bulging/stretched. The rears look like they could actually go up a little more (285?) to achieve the same flat sidewall as the front. Not sure if that will mess with the car computer, performance or overall look of the car from the side.
It will cause a speedo error of a little over 2% and increase the ride height of the rear by 0.27"
Putting the 245's on the front increases the ride height by 0.15" as well
Old 02-11-16, 08:37 AM
ItzFilyO
ItzFilyO's Avatar
Received 1,046 Likes on 661 Posts
Oh those plus sizes look perfect for the GS wheels. The OEMs are stretching a bit and I don't like it.
I'll be going with that size for sure. What's the rating on the Pilot SS? More than 30K miles?
islandbeef
islandbeef's Avatar
I'm actually thinking of ordering a set of Falkens from Discount in the OEM staggered sizes. The prices are less than the fore-mentioned brands, performance is good, I'm not going to track my car and I'm not trying to impress anybody.
/shrugs
Old 02-11-16, 10:18 AM
Byprodrive
Byprodrive's Avatar
MPSS's are rated 30K unlees it's a staggered fitment preventing rotation. In that case they are rated 15k miles. That's the only tire I have bought since they were available. Be aware that deviating from oe tires may cause more noise, check the tread pattern before buying.
Old 02-11-16, 10:28 AM
ItzFilyO
ItzFilyO's Avatar
Only 15K miles? Oh no thanks then.
Quick Reply: F Sport RWD Tire options
