2016 GS tail light to 2013-15
#33
Originally Posted by Nixus
You gonna copy me now huh? J/KGot the working fine, forgot to update this thread since I had some other projects at hand.
Outside units need load resitors to prevent hyper blinking. Inner units need some rewirring along with changing out 2 connectors.
boostinsc (09-30-20)
#42
0mghi2u: Looks great! You have the most unique look going on there with the taillights and custom work...awesome!
lexus4jess (03-22-21)
#44
Outer units, yes but you have hyper blinking. ( add load resistor )
inner units no, the lights have 5 wires and the old ones 4 so you either need to swap out the connector on the trunk harness to be a 6 pin connector to match the one on the light or you can use the connector of the old lighs and put that on the light.
If you use the old connector you'll have 1 loose wire hanging.
New lights have 5 wires.
Fog -- you don't have those but the wire is there.
Reverse --
Tail light --
Brake light --- ( doesnt need to be connected if you only have the outer units light up when braking 0
Ground --
You can use a small prying tool to release the pins from the connector to swap out the connectors to make things fit.
Reverse --
Tail light --
Ground --
