Opening up rear-view mirror
Is there a non-destructive way of opening up the read-view mirror? Of course I can pry off the two sides but I'm afraid the edges will chip and bend where I'll insert the prying tool. Anyone did this before? Thanks
I cannot answer your question. But, why do you want to open up the rear-view mirror?
Don't pry the two halves open! Lol
Tilt the mirror glass all the way to one corner and slowly pry the glass (with you fingers) off of the base it is attached to with clips. It takes some force to do. Once the glass mirror is removed, there should be six (?) screws. After removing the screws the mirror housing halved come apart and you can access the bulb.
This works for MY '13-'15 btw. I don't if Lexus decided to change it up on us for the '16.
So if I push in one corner, the glass will swivel and push out the opposite corner until I can grab it with my fingers and pull the glass out?
Originally Posted by metrathon
Never expected that, greatly appreciate the advice.
Using the driver mirror as reference, tilt the mirror using the controls all the way up and to the right so you can get your fingers under the bottom left of the mirror, then pry it off. Honestly, getting to those bulbs in the mirror isn't particularly difficult, but it was unnerving enough to where I only got around to getting one bulb changed.
Saw this DIY awhile back on the nx forums. Looks very similar or exactly the same as the one used in the GS (except for 2016 and above models).
https://www.clublexus.com/forums/nx-...ew-mirror.html
