Car stalls while stopped in Drive, when brake pressed firmly
'15 Gs350 FSport. 4K miles. I have been able to replicate this issue, and won't have time to bring it into shop until next week. Figured you guys would know what the issue is.
I am at a stop light after driving for a bit. Car in drive obviously, foot on brake. If I press the brake very firmly, almost to where it hits the floor board, the slip indicator light comes on and flashes, and call stalls (or goes into idle). I am forced to shift car into park, and then shift back into drive. Or I have to turn car off, and back on again.
First time it happened I had no idea what was going on - I was reaching over to the passenger seat while at a stopped light and pressed down the brake pretty hard by accident. But I am now able to replicate it.
Thoughts?
Thoughts?
Try it again, this time step on the gas or let off the brake and wait a couple of seconds. Pressing the brake pedal firmly until the traction light flashes indicates hill assist. Meaning it'll hold your brake for a few seconds before releasing; this way you don't roll back and love tap the car behind you. disengages after a few seconds or when the gas pedal is depressed.
Now if your engine turns completely off there's something wrong with your hill assist.
Correct, you're activating hill start assist. If you just gave it some gas, it would kick off.
I wonder at what hill grade most vehicles tend to roll backward when the driver's foot is lifted off the brake pedal but before the gas can be applied to cause forward movement? Or, when vehicles tend to roll backward even though the driver has his or her foot moderately on the brake pedal? Maybe it's time for those people to learn how to drive with both feet (when necessary).
These hills may present a problem...
In my experience with modern cars it has to be pretty steep...
Pretty certain that you just activated the hill hold assist feature. You should've heard a beep and see the traction light flashing when activated. If you release the brake after activating it, it will hold for a few seconds and then release as indicated by two beeps. As others have stated, you can also deactivate it by stepping on the gas (no beeps, but flashing traction light turns off).
Good thing you consulted here first. Saved you a trip to the dealer.
The original poster did not reply yet so I hope he reads this thread before taking the car in to the dealer. Better us explain this feature than have the dealership explain it and make him feel stupid.
Note that this is also a great feature to use to launch your car with from a stop light. But this feature will not help you get better times on the drag strip.
My CT will roll backwards on any hills when in D, even ones that aren't that steep, these electric cars can't hold like normal cars.
My GS450h has a "hold" feature to prevent it from rolling at all. It basically functions like you holding the brake pedal down and then when you push down on the gas enough, it will automatically released the brake for you. Pretty useful.. we don't have many steeps hills in TX, so my use of it has been mainly in stop & go traffic (which is what I believe it was intended for) and in drive thru restaurants!
~ Im2bz2p345
~ Im2bz2p345
The LS has that, I like it, The 2016 GS has it also.
