20x10.5 or 20x10?
Old 12-07-15, 10:11 AM
SSTG
SSTG's Avatar
Default 20x10.5 or 20x10?
I'm wanting to order a set of wheels for my FSport all-wheel-drive. From what I read on the forum it's mixed results. I do not want the wheels to stick out at all.
From my research, I need 20x9 32MM offset with 245/35/20 on the front and 20x10.5 45MM with 285/30/20 on the rear. I will be lowering the Car on Tanabes.
Could members with both mentioned sizes post pics? Preferably from top down and from the rear?
I would also appreciate your thoughts?
Thank you guys!
Old 12-07-15, 10:47 AM
mrpartsman
mrpartsman's Avatar
you can run 10.5 in the rear but with lowering it and running it with 285 u will rub for sure , I am running 10.5 and with 275 I sometimes rub and I am running tanabes also,so much safer with 275 or else u will have to do some shaving on the rear fenders, I have seen it.
Old 12-07-15, 10:51 AM
SSTG
SSTG's Avatar
^Thank you for the reply. Does your car rub with the 45MM offset?
Also, I was going to run Hankook tires. They run thinner than most...
Old 12-07-15, 11:32 AM
mrpartsman
mrpartsman's Avatar
no unless I have ppl sitting in the back and I will go over a bump fast or a nasty driveway, or else not all, and the hankook v12 are very nice tires and I am very happy with it.
Old 12-07-15, 11:36 AM
jtrue28
jtrue28's Avatar
Keep in mind he has the AWD, so rolling diameter needs to be very close on all four. 285/30/20 is the right size to match up with 245/35/20. I know other folks have gotten 275/30/20, but am unclear if they did that on the AWD setup.
Old 12-07-15, 12:01 PM
SSTG
SSTG's Avatar
To be clear, you have 20x10.5 45mm offsets and are running Hankook 275/30/20 rear tires and still rub at times?
If that's the case, there is no way I could do 285/30/20 like the Manufactuer is telling me! The wheels will be custom so I can't return them if they don't fit.
And as the other member said, I am AWD and need the tires to match...
Old 12-07-15, 01:03 PM
mrpartsman
mrpartsman's Avatar
yes if they even tell u u cant run 285 then don't, u don't want to marry those tires and figure out the hard way, then u will damage the tires and u cant resell them and now u have to go buy 2 brand new tires, so wait and see if anyone will respond don't rush and if they have the AWD.
Old 12-07-15, 01:42 PM
SSTG
SSTG's Avatar
Thanks.
I have two conflicting answers from the top two wheel companies on this forum as to will 285mm work.
285 vs 275mm is important to me as I have AWD and 245/35 and 285/30 are the same overall diameter.
Thanks again for all of your help.
Old 12-07-15, 01:57 PM
mrpartsman
mrpartsman's Avatar
u got it , look on the forum u should be able to find someone with AWD car with wheels on, good luck and post some pics also before and after.
Old 12-08-15, 08:39 AM
SSTG
SSTG's Avatar
Bump. Appreciate the help
Old 12-08-15, 08:47 AM
jtrue28
jtrue28's Avatar
Will they only rub if you lower it? That may be where you will need to compromise.
Old 12-08-15, 10:48 AM
SSTG
SSTG's Avatar
Thanks for the reply.
I have to lower it as I have the 4x4 (AWD) look going on, lol!
I am planning on Tanabe so it won't be a drastic drop.
Old 12-08-15, 05:18 PM
jtrue28
jtrue28's Avatar
You can run different size tires on the AWD...just be warned that it will likely cause the AWD system to wear pre-maturely.
Old 12-08-15, 05:48 PM
SSTG
SSTG's Avatar
Thanks jtrue. There's 2MM difference between 285 & 275, I don't "think" it will cause damage but I want the best fitment you know? I was hoping someone running the same set up would chime in...
Old 12-09-15, 12:25 AM
terrycs
terrycs's Avatar
285 on 10" with 48mm offset will not rub in the rear even if the car is fully loaded.
https://www.clublexus.com/forums/gs-...n-f-sport.html
Quick Reply: 20x10.5 or 20x10?
