TPMS Reset?
So every time we rotate tires, we have to do a reset??
I don't think so. I've rotated my tires every 5k miles with no issues. If the wheel size is changed the metrics are different, and I think then it becomes an issue of re-calibration.
A 'Direct TPMS' system (like used on the GS 350) typically does not normally require regular calibration, however there are occasions where the sensors may need to be reprogrammed if tires are replaced or after a rotation. I believe most tire shop employees just reset all TPMS systems after a rotation because the shop employees aren't always sure whether the vehicle has an Indirect or Direct TPMS system...or if a Direct TPMS system (that normally doesn't need to be reset) needs it this particular time.
Thanks. '13 here so assume no issue.
How does a non-Lexus tire shop reset all the different TPMS systems? Is it a code reader, a special computer, or some other gizmo?
BTW, when I was at the Firestone dealer yesterday to have my tires installed (drop-shipped by Tire Direct), they were going to charge an additional $20 for "TPMS service." They did not argue when I said that my 13 GS doesn't need any such service, but they should have known, and all should be careful about these sneaky upcharges (my favorite is shop supplies - 6%, regardless of whether or not they use any rags, solvents, cleaners, etc) It would have been nice if the techs who changed my tires had used one of those rags I paid for. Instead, they left greasy hand-prints all over the wheels.
I always do business with Discount Tire. They have always given me superior service and pricing, plus they have Hunter GSP9700 Road Force balancing machines. When Discount Tire replaces tires they always recommend a TPMS Basic Kit (O-Ring, Grommet/Seal) for $6 per wheel, which I always do. I suspect 99% of all customers have this done.
Since you bought your tires at Tire Rack, Tire Rack says; It is best to remove the TPMS sensor (and the attached valve stem) when removing a tire from the wheel. This avoids any damage caused by breaking the tire bead loose from the wheel as well as seating the new tire onto the wheel. Once the sensor has been removed, it will require a new "O" ring and/or compression ring to seal the sensor properly. Whenever aluminum TPMS sensors are removed from a wheel, the sensor should be fitted with a new rubber grommet (also called an o-ring or seal).
texas008
11-22-17 05:07 AM
avanchieri
12-02-16 04:48 AM
WhitBaby
10-14-08 08:37 AM
