tire pressure 275/30/20
Old 09-25-15, 11:02 PM
hube
hube's Avatar
Default tire pressure 275/30/20
Hi,
Since my tires didn't last that long (15000km) and the tread finished on the outsides (which is normal when running a setup with bigger wheels and tires according to the tireshop), I am wondering what tire pressure you guys are on. I think that with the tread wear my pressure may be a bit low. It is set to 2.4 bars (34.8 psi).
This is regarding my rear tires (275/30/20 with 10.5j wheels)
What have pressure have you set (please only with similar setup)? Or if professional, what do you recommend?
Old 09-26-15, 03:13 AM
SNiiP3R
SNiiP3R's Avatar
I usually run between 36psi - 38psi
Old 09-26-15, 09:47 AM
Im2bz2p345
Im2bz2p345's Avatar
^^ Same. I try to maintain around 37 in all tires.
~ Im2bz2p345
Old 09-26-15, 10:25 AM
akuma88
akuma88's Avatar
I run 40psi all around. Usually in the morning its at 37psi but when once you start driving they raise up to 40psi
Old 09-26-15, 11:17 PM
hube
hube's Avatar
thanks guys!
DaVeyBoyTX
11-04-13 03:00 PM
Rezaxxed
Wheels, Tires & Brakes Forum
12-15-08 10:12 PM
Ozzy
04-01-08 07:06 PM
flossn
04-04-05 12:17 AM
GS4ADRLexo
01-26-03 11:56 PM
Quick Reply: tire pressure 275/30/20
