20's mess up Differential with AWD Car?
I just bought a set of 20's for my 2013 GS350 AWD
Front: 20x9
Rear: 20x10.5
I was told to run this setup (F) 245/35/20 (R) 20x10 275/30/20 but will that mess up my differential for my AWD? Can anyone assist me with this if it's okay to run this setup or not. Thanks!
Front: 20x9
Rear: 20x10.5
When you drive on smooth roads the distribution is 30/70, rear wheels get more power. However, the AWD system will engage in low traction and the distribution will change to 50/50. if you install incorrect tires the AWD will think that your tires are slipping and will change the distribution to 50/50. Driving like that for long period of time will cause mechanical damage.....
I have a 2013 GS350 AWD. Which tires would be best for this setup? Ride height is stock now, but may consider dropping it a bit.
Front: 20x9 Offset 35mm
Rear: 20x10.5 Offset 45mm.
Which is better to have
F: 245/35/20 and R: 285/30/20
or
F:245/35/20 and R: 275/30/20.
Please help, Thanks!
or
Go with this set up, you'll be fine
or
or
