Dealer only settings access?
Does anyone know how I can get access to the "dealer only" settings? There are a series of settings that can "only" be set by the dealer, but I was wondering if anyone know the way to do it w/o having to visit the dealership to get it done.
Lexus Personalized Settings
Your should be searching for "lexus personalized settings". Don't know what year your car is so you can try this link for the Gs350 to start. The forum also has a wealth of info. Good luck!
And just in case... http://www.lexus.com/pdf/service/GS_with_nav_LPS.pdf
Yes, that's the pdf that I looked at but the part that I'm interested in is the "dealer only" section. I want to be able to change the settings like window roll down with the unlock button. btw, it's a 2015 GS350.
Do you think you will only change the setitngs once? If so, it would be ok at the dealership.
I like being able to adjust anything on a whim. With Carista, no appointment, driving to the dealer, and for sure no cost after the modest initial investment.
Even if the dealer was free for life , I would use the Carista app. My time (wasted at a dealership) is worth more to me.
For the 2015 GS350, does anyone know if the Carista dongle can adjust the Auto Lock by Speed?
Because in 2015, Auto Lock by Speed is not adjustable in the Menu System.
Where do we plug this Carista dongle into?
a list of things adjustable
http://www.caristaapp.com/customizat...xus_gs350_2013
Doors / Windows / Remote:
Blink turn signals when locking/unlocking with remote
YES / NO
Beep when locking/unlocking with remote
YES / NO
Volume of beep when locking/unocking with remote
OFF / 1 / 2 / 3 / 4 / 5 / 6 / MAX
Beep when opening/closing windows with remote
YES / NO
Warn when door can't be locked with remote because it's open
YES / NO
Warn when a window is still open when locking doors
YES / NO
Warn when sunroof is still open when locking doors
YES / NO
Panic function on remote
ENABLED / DISABLED
Open trunk lid with remote
SINGLE CLICK / DOUBLE CLICK / LONG PRESS / VERY LONG PRESS / DISABLED
Re-lock doors automatically if you unlock, but don't open a door
YES / NO
Re-lock doors automatically if you unlock, but don't open a door within…
30 SECONDS / 60 SECONDS / 120 SECONDS
Unlock doors via remote
DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND / ALL DOORS ON 1ST PRESS
Unlock doors via physical key
Unlock doors via smart key (door handle button)
Auto-lock doors when moving
ON / OFF
Lock doors when shifting into gear
ON / OFF
Unlock doors when shifting into park (P)
ON / OFF
Unlock all doors when driver's door is opened
ON / OFF
After locking with smart key, allow re-opening within…
0.5 SECONDS / 1.5 SECONDS / 2.5 SECONDS / 5 SECONDS
Smart key location to start car
FRONT SEATS / ANYWHERE IN VEHICLE
Unlock trunk when smart key in range
YES / NO
Open windows and sunroof by holding key in door lock
ON / OFF
Close windows and sunroof by holding key in door lock
ON / OFF
Open windows and sunroof via long-press on remote
ON / OFF
Auto fold side-view mirrors (req. power folding mirrors)
WITH IGNITION / WITH DOOR LOCKS / DISABLED
Lower passenger-side mirror when in reverse gear (req. memory seats)
DEFAULT / USER-SPECIFIED
Instruments / Display / Dings:
Engine start indicator
ON / OFF
Display odometer after ignition is turned off for…
30 SECONDS / 1 MINUTE / 10 MINUTES / OFF
Ding when headlights are left on
YES / NO
Seat belt warning ding (driver)
ENABLED / DISABLED
Seat belt warning ding (front passenger)
ENABLED / DISABLED
Turn signal click volume
LOW / MEDIUM / HIGH
Remote low battery warning
ON / OFF
ECO Drive indicator zone
ON / OFF
Lights:
Daytime running lights
ON / OFF
Coming-home lights duration
OFF / 30 SECONDS / 60 SECONDS / 90 SECONDS
Auto headlights activation threshold
DARKEST / DARKER / NORMAL / LIGHTER / LIGHTEST
Turn on marker lights when vehicle is unlocked via remote
ON / OFF
Instrument lights dimming sensitivity
Instrument lights restoring sensitivity
Dim interior lights after…
7 SECONDS / 15 SECONDS / 30 SECONDS
Turn on interior lights when you shut off engine
YES / NO
Turn on interior lights when you unlock doors
YES / NO
Turn on interior lights when smart key in range
YES / NO
Interior footlight (bright when doors open, dim when driving)
YES / NO
Turn on interior door-handle & center console lights dimly (flood lights) when ignition is on and shifter is not in park (P)
YES / NO
Turn on exterior footlight (on side mirror) when smart key in range
YES / NO
Turn on exterior footlight (on side mirror) when doors unlocked via remote
YES / NO
Turn on exterior footlight (on side mirror) for…
OFF / 7 SECONDS / 15 SECONDS / 30 SECONDS
Interior light control
ENABLED / DISABLED
Exterior light control
ENABLED / DISABLED
Heater & A/C:
Temperature dial calibration
-2°C / -1°C / NORMAL / +1°C / +2°C
Ambient temperature calibration
-3°C / -2°C / -1°C / NORMAL / +1°C / +2°C / +3°C
A/C evaporator control
AUTOMATIC / MANUAL
A/C ECO mode
ENABLED / DISABLED
Auto-increase blower speed when front defroster is on
YES / NO
Auto-turn on A/C when AUTO button pressed (if needed)
YES / NO
Deactivate front defroster when AUTO button pressed
YES / NO
Also blow to feet in "face" mode
YES / NO
Seat heater mode
AUTOMATIC / MANUAL
Fan speed reaches its target…
SLOWLY / NORMALLY / FAST
Other:
Roll down rear shade when in reverse gear
YES / NO
Delay for rolling down rear shade when in reverse gear
IMMEDIATE / 0.7 SECONDS / 0.9 SECONDS / 1.2 SECONDS
Slide driver's seat back for easy exit
OFF / SHORT / STANDARD
Move driver's seat side support for easy exit
YES / NO
Move driver's seat lumbar support for easy exit
YES / NO
Move driver's seat pelvis support for easy exit
YES / NO
Move passenger's seat side support for easy exit
YES / NO
Move passenger's seat lumbar support for easy exit
YES / NO
Move passenger's seat pelvis support for easy exit
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
ENABLED / DISABLED
YES / NO
ON / OFF
ON / OFF
ON / OFF
ON / OFF
YES / NO
ON / OFF
ON / OFF
ON / OFF
ON / OFF
YES / NO
ENABLED / DISABLED
ENABLED / DISABLED
LOW / MEDIUM / HIGH
ON / OFF
ON / OFF
Lights:
ON / OFF
ON / OFF
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
ENABLED / DISABLED
ENABLED / DISABLED
Heater & A/C:
AUTOMATIC / MANUAL
A/C ECO mode
ENABLED / DISABLED
YES / NO
YES / NO
YES / NO
YES / NO
Seat heater mode
AUTOMATIC / MANUAL
Other:
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
