A/C is Struggling
Old 07-28-15, 12:05 PM
zicogold
zicogold's Avatar
Default A/C is Struggling
I have a 2 1/2 year old car and with temperatures up around 34-35 Celsius (93-95 F) today, the air conditioner in the car is taking about 10 to 15 minutes of driving before any appreciable cool air is being vented into the car. I don't recall this delay in the air conditioning the previous two summers. Is anyone experiencing similar performance from their A/C, or do I need to visit the dealer?
Old 07-28-15, 12:12 PM
bclexus
bclexus's Avatar
Received 1,994 Likes on 1,417 Posts
My A/C works great in the Texas 100+ degree temperatures.
Are you sure the A/C is turned On? If so, you need to see your dealer.
Old 07-28-15, 12:25 PM
ItzFilyO
ItzFilyO's Avatar
Received 1,046 Likes on 661 Posts
Also check the direction of the airflow, if it's blowing to the windshield it will take a lot longer to cool down the interior. I have mine blow to the windshield to cool my dash cam and radar detector.
Old 07-28-15, 12:39 PM
MEAHT
MEAHT's Avatar
Its the GS. My 2009 IS had the coldest AC ive ever seen in any car, it threw ice cubes at you!
Old 07-28-15, 01:19 PM
GregCanada
GregCanada's Avatar
Mine was working fine yesterday, but i noticed i had to set the Auto temp to 22-23degC, instead of 25degC where i usually set it, to get the same effect. Close the sunroof cover and the rear sunshade - it is hotter than last summer!
If this doesn't fix the issue - dealer time. Should be under warranty.
Old 07-28-15, 02:10 PM
Bartman619
Bartman619's Avatar
Put the AC on recirc.
Old 07-28-15, 03:13 PM
zicogold
zicogold's Avatar
Yeah I think two things which may delay the a/c operating at full capacity is that my wife tells me she finds it too cold when driving alone and so turns the fan down and the auto function turns off. So I think it takes a few minutes for the a/c to spool up, that and parking the car in direct sun with a high ambient temperature will also delay the cold air.
We leave the a/c on at all times as the toggle is buried in the Climate screen and we still need the dehumidifying effect in the winter.
Old 07-28-15, 03:22 PM
jkeller
jkeller's Avatar
A black/black car here in Texas and no problems with the heat. Do you have the s-flow on? No plastic bags sucked in and blocking the radiator, both electric fans working? There is a freon sight glass but its in front of condenser on drivers side, I've never tried to get my head down in there to see it though. Oh yeah, I know they stopped using freon r12 a long time ago. Freon is just a cool word.
Old 07-28-15, 03:26 PM
FishBike
FishBike's Avatar
No issues here, and I'm in the same part of the world you are. I get cool air within 30 seconds of starting the engine. I generally leave it set at 22, auto, s-flow on. Is it that you're getting no air from the vents for a long time, or the air is warm?
Old 07-28-15, 03:48 PM
KidKlutch2
KidKlutch2's Avatar
Also Eco mode reduces the A/C output so it may take longer to cool off
Old 07-28-15, 03:57 PM
GSteg
GSteg's Avatar
Something is definitely wrong here. It should not take 10-15 minutes to start blowing cold air. Usually it's within seconds where you can feel cold air coming out of the vents if you place your hand over them.
Old 07-28-15, 04:33 PM
Bartman619
Bartman619's Avatar
...Another thing could be the a/c filter may be clogged and needs changing.
Old 07-28-15, 05:06 PM
bclexus
bclexus's Avatar
I think you just found out why it takes so long to cool down! If you turn the fan speed down low you are not going to have a normal cool down in a minimal time period. The Auto function will automatically lower the fan speed as needed based on the temperature set. Set it on Auto and let it perform automatically...
Old 07-28-15, 05:50 PM
puffdaddy
puffdaddy's Avatar
Is your AC going into recirc mode? Just wondering since improper AC cabin filter replacement can cause the recirc gear to break. Of course, if it's pulling hot outside air, it would run at Max, and take much longer to cool
Old 07-28-15, 07:46 PM
fhan888
fhan888's Avatar
Would a clogged cabin filter have any effect on this?
Quick Reply: A/C is Struggling
