Oil Filter Housing
Oil Filter Housing
Does anyone know if there is an alternative oil filter housing or does toyota make one size only?
found an upgrade housing on amazon but it's just a replacement
APDTY 028127 Oil Filter Cap/Housing For Toyota/Lexus (Cartridge Type)
If you want a sexy underpan add bit of bling with a fumoto valve.
The 2gs had a larger filter that is almost twice the size of the oem...i'm looking for the same setup. I doubt there is an option besides building a custom one - which is a no-go.
I've never changed my oil on the 4gs myself so i didn't know it was metal. What i'm looking for is a larger filter so that there would be more surface area for the oil to flow into. That way, you can run a much higher contraint filter and also have higher flow.
jeeper2269
01-26-16 06:38 PM
