What dealer only settings should I have changed?
Old 05-07-15, 05:17 PM
Cndnbkn
Cndnbkn's Avatar
Default What dealer only settings should I have changed?
Hi all,
Heading to the dealership tomorrow to get a full rundown on my GS(just picked it up a week ago). I am going to have them change a few dealer only settings while I am there, like all windows and sunroof down by holding unlock.
Any other dealer only custom settings you think I should have changed?
Anyone know if you can have the power trunk set to close from inside the car? That would be a very nice function to have.
Thanks in advance.
Old 05-07-15, 06:13 PM
xRYD3Rx
xRYD3Rx's Avatar
You can change how many times you want the turn signals to flash - Its set @ 3 standard.
I changed mines myself to 5.
Old 05-07-15, 09:03 PM
Rudiculous
Rudiculous's Avatar
Originally Posted by xRYD3Rx
You can change how many times you want the turn signals to flash - Its set @ 3 standard. I changed mines myself to 5.
As well as the volume level of the blinker
Old 05-08-15, 12:33 AM
xRYD3Rx
xRYD3Rx's Avatar
Volume level?
Hmm never knew you can change that but its not that loud is it?
Mines not changed but seems normal
Old 05-08-15, 04:00 AM
swfla
swfla's Avatar
Received 1,302 Likes on 1,005 Posts
I believe that the dealer should have a printed list of all custom settings available for each model as there are differences. They should be able to produce that for you to look over before deciding.
Old 05-08-15, 08:26 AM
bclexus
bclexus's Avatar
Received 2,276 Likes on 1,622 Posts
Here (see attachment) is the 2013 GS 350 Lexus Personalized Settings that are available. It explains how to change the settings that can be changed by the owner or dealer using the NAV system, and it lists the other settings that can only be changed by the dealer or using the Carista App.
Old 05-08-15, 10:21 AM
tompass
tompass's Avatar
Get the Carista App and do it yourself.
Old 05-08-15, 12:30 PM
Cndnbkn
Cndnbkn's Avatar
Thanks BCLEXUS. That pdf is very helpful.
Why in the world can't lexus let you close the trunk from the inside switch or remote? Every SUV and minivan I have driven has this functionality.
Is there a non dealer way to program this?
Old 05-08-15, 12:37 PM
kmm
kmm's Avatar
Maybe because every minivan and SUV has windows to let you see who or what might be inside the vehicle?
Are there cars that enable you to close the trunk from the inside switch?
Old 05-08-15, 12:47 PM
bclexus
bclexus's Avatar
I'm guessing it must be a safety issue pertaining to trunks. I suspect the function is not operable from inside the car in the US/Canada. The rear door on the SUVs and minivans do not close a concealed area 'trunk' per se, but instead just another door to the occupant sitting area.
Old 05-08-15, 05:58 PM
mcomer
mcomer's Avatar
Nice besides the Remote Window/Sunroof Open is the driver's door lock key All Window/Sunroof close.
Have you ever had to return to a car to close them...unlock the car, start or accessory the key and then hold one or more switches? Now just insert the key in the driver's door and twist CCW...all done and locked also!
Old 05-08-15, 07:43 PM
ItzFilyO
ItzFilyO's Avatar
Received 1,050 Likes on 664 Posts
I don't know if u can change the number of turn signal on the 2015 with the OBD2 tools cause my 2014 cannot. U have to do the windshield wipers stalk trick to change it. But my 2015 CT lets me change it through the OBD2.
Old 05-09-15, 10:33 AM
Carista
Former Sponsor
Carista's Avatar
Hey guys, here's a sample list of "dealer-only" settings that you can change BY YOURSELF with the Carista app for Android or iOS (and a compatible OBD device):
(note: we're also adding a new lane-change blinker count setting that may or may not work on the GS - please PM me if you're interested in trying it in our latest beta version).
Doors / Windows / Remote:
Blink turn signals when locking/unlocking with remote
YES / NO
Beep when locking/unlocking with remote
YES / NO
Volume of beep when locking/unocking with remote
OFF / 1 / 2 / 3 / 4 / 5 / 6 / MAX
Beep when opening/closing windows with remote
YES / NO
Warn when door can't be locked with remote because it's open
YES / NO
Warn when a window is still open when locking doors
YES / NO
Warn when sunroof is still open when locking doors
YES / NO
Panic function on remote
ENABLED / DISABLED
Open trunk lid with remote
SINGLE CLICK / DOUBLE CLICK / LONG PRESS / VERY LONG PRESS / DISABLED
Re-lock doors automatically if you unlock, but don't open a door
YES / NO
Re-lock doors automatically if you unlock, but don't open a door within…
30 SECONDS / 60 SECONDS / 120 SECONDS
Unlock doors via remote
DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND / ALL DOORS ON 1ST PRESS
Unlock doors via physical key
Unlock doors via smart key (door handle button)
Auto-lock doors when moving
ON / OFF
Lock doors when shifting into gear
ON / OFF
Unlock doors when shifting into park (P)
ON / OFF
Unlock all doors when driver's door is opened
ON / OFF
After locking with smart key, allow re-opening within…
0.5 SECONDS / 1.5 SECONDS / 2.5 SECONDS / 5 SECONDS
Smart key location to start car
FRONT SEATS / ANYWHERE IN VEHICLE
Unlock trunk when smart key in range
YES / NO
Open windows and sunroof by holding key in door lock
ON / OFF
Close windows and sunroof by holding key in door lock
ON / OFF
Open windows and sunroof via long-press on remote
ON / OFF
Auto fold side-view mirrors
WITH IGNITION / WITH DOOR LOCKS / DISABLED
Lower side-view mirror when in reverse gear
DEFAULT / USER-SPECIFIED
Instruments / Display / Dings:
Engine start indicator
ON / OFF
Display odometer after ignition is turned off for…
30 SECONDS / 1 MINUTE / 10 MINUTES / OFF
Ding when headlights are left on
YES / NO
Seat belt warning ding (driver)
ENABLED / DISABLED
Seat belt warning ding (front passenger)
ENABLED / DISABLED
Turn signal click volume
LOW / MEDIUM / HIGH
Remote low battery warning
ON / OFF
ECO Drive indicator zone
ON / OFF
Lights:
Daytime running lights
ON / OFF
Coming-home lights duration
OFF / 30 SECONDS / 60 SECONDS / 90 SECONDS
Auto headlights activation threshold
DARKEST / DARKER / NORMAL / LIGHTER / LIGHTEST
Turn on marker lights when vehicle is unlocked via remote
ON / OFF
Instrument lights dimming sensitivity
Instrument lights restoring sensitivity
Dim interior lights after…
7 SECONDS / 15 SECONDS / 30 SECONDS
Turn on interior lights when you shut off engine
YES / NO
Turn on interior lights when you unlock doors
YES / NO
Turn on interior lights when smart key in range
YES / NO
Interior footlight (bright when doors open, dim when driving)
YES / NO
Turn on interior door-handle & center console lights dimly (flood lights) when ignition is on and shifter is not in park (P)
YES / NO
Turn on exterior footlight (on side mirror) when smart key in range
YES / NO
Turn on exterior footlight (on side mirror) when doors unlocked via remote
YES / NO
Turn on exterior footlight (on side mirror) for…
OFF / 7 SECONDS / 15 SECONDS / 30 SECONDS
Interior light control
ENABLED / DISABLED
Exterior light control
ENABLED / DISABLED
Heater & A/C:
Temperature dial calibration
-2°C / -1°C / NORMAL / +1°C / +2°C
Ambient temperature calibration
-3°C / -2°C / -1°C / NORMAL / +1°C / +2°C / +3°C
A/C evaporator control
AUTOMATIC / MANUAL
A/C ECO mode
ENABLED / DISABLED
Auto-increase blower speed when front defroster is on
YES / NO
Auto-turn on A/C when AUTO button pressed (if needed)
YES / NO
Deactivate front defroster when AUTO button pressed
YES / NO
Also blow to feet in face mode
YES / NO
Seat heater mode
AUTOMATIC / MANUAL
Fan speed reaches its target…
SLOWLY / NORMALLY / FAST
Other:
Roll down rear shade when in reverse gear
YES / NO
Delay for rolling down rear shade when in reverse gear
IMMEDIATE / 0.7 SECONDS / 0.9 SECONDS / 1.2 SECONDS
Slide driver's seat back for easy exit
OFF / SHORT / STANDARD
Move driver's seat side support for easy exit
YES / NO
Move driver's seat lumbar support for easy exit
YES / NO
Move driver's seat pelvis support for easy exit
YES / NO
Move passenger's seat side support for easy exit
YES / NO
Move passenger's seat lumbar support for easy exit
YES / NO
Move passenger's seat pelvis support for easy exit
YES / NO
Old 05-10-15, 01:18 PM
Afrosheen
Afrosheen's Avatar
That 3 blinks to 5 blinks for the soft turn signal setting is a must. It took my dealer 1.5 hours to figure it out (had to call corporate and youtube it I guess) because nobody else had ever requested it. It gives you a nice extra second or so to move lanes gently on the highway, and the way people drive here, I try to communicate as perfectly as possible with signals. It kinda telegraphs your intention so people that were about to cut over may hesitate and let you in...or so the theory goes.
Old 05-11-15, 04:23 PM
Kane007
Kane007's Avatar
I bought the hardware for the Carista app and just customized some of my settings. But the main one I wanted to do doesnt seem available.. I want to change the number of times my turn signal flashes when I change lanes.. I hate that it is only 3 flashes, I would like 5 or 6. I thought I was able to change this but I do not see the option available I have a 2013 GS350
Quick Reply: What dealer only settings should I have changed?
