buzzing sound around the radio / cup holders?
Old 05-06-15, 03:39 PM
rominl
exclusive matchup
rominl's Avatar
Default buzzing sound around the radio / cup holders?
can't exactly pinpoint this yet but for sure it's very consistent. every morning when the car is cold (and been sitting for 12 hours), when i get in the car and start, within the first 5-10 seconds, there will be a long buzzing noise coming from behind the radio or cup holder area. i don't feel anything is vibrating though. it goes on for like 2-3 seconds, then off, and usually another few seconds there will be another one or two short ones. after that everything is fine
when i leave work (warmer), i don't seem to hear anything at all.
Old 05-06-15, 03:49 PM
SNiiP3R
SNiiP3R's Avatar
Is your cup holder cover open at the time ? I have an aftermarket exhaust, so I get all kinds of noises when it's cold lol, but I found that when I have the cover closed it does not make that buzzing noise.
Old 05-06-15, 09:20 PM
rominl
exclusive matchup
rominl's Avatar
yes it is. but my car is stock though, i would be very surprised if the any of the exhaust vibrations can transfer in?
Old 05-06-15, 09:59 PM
4matador
4matador's Avatar
The center divider in the cup holder can some times rattle if it is no sitting tight; try taking it out and put it back in to see if solves your problem.
Old 05-06-15, 10:18 PM
dreamG
dreamG's Avatar
Did it sound like a stuck CD? I have something like you described and usually go on for 30-60 seconds. Definitely not a cup holder related issue. I still don't know what it is caused from.
Old 05-07-15, 05:03 AM
kpred1970
kpred1970's Avatar
I had the same stuck cd sound, like a continuous spinning of a cd even though the cd slot was empty. Took my car to the dealer. Service advisor was able to hear it also. Had radio replaced under warranty. Issue went away. It's been about a month now and so far no stuck cd sound.
Old 05-07-15, 06:48 AM
bigblack06
bigblack06's Avatar
Could be the air vents opening.
Old 05-07-15, 06:49 AM
Received 2,519 Likes on 1,817 Posts
I also had the same issue rominl, next time it happens, try putting the car in neutral, or pushing on the side of the console with your right leg, it should go away.
They had to replace my cupholder assembly. They tried stuffing "quiet kit" padding in that padded trim area but that wasn't the issue. The issue is the cupholder assembly itself.
Old 05-07-15, 07:18 AM
Sheik723
Sheik723's Avatar
I have a buzzing sound coming from my radio area as well. Sounds like the cd skipping sound as previously stated. I'm moving to a different state in 2 weeks so I think I will wait until my move to get it replaced.
Old 05-07-15, 07:47 AM
bclexus
bclexus's Avatar
Received 1,991 Likes on 1,415 Posts
That is an excellent guess of what could be making the brief noise at start-up - especially since it is temperature dependent.
Old 05-07-15, 07:51 AM
MEAHT
MEAHT's Avatar
are these all 2013? A ton of these issues pop up on the 2013 model.
On my 2015 I can see how they fixed the rattles on cup holder by adding felt material all around it
Old 05-07-15, 07:57 AM
Mines a 2013 but rominl's is a 2015.
Old 05-07-15, 08:15 AM
MH6
MH6's Avatar
I had a similar issue, a continuous buzzing noise that was coming from behind the radio cup area, which would change frequency. Heard on start and shut down or when radio volume was low and parked. Took to dealer, had their top tech listen, turned out to be a cooling fan for the radio amp. Radio head unit replaced and problem solved.
Old 05-07-15, 11:26 AM
rominl
exclusive matchup
rominl's Avatar
mine is 2015 and this has been going on for a month (3 months ownership).
i tried taking out the cup holder divider this morning and closed the lid before starting the car, same thing, buzzing down. i can hear it right behind the radio. i tried pushing on the side panel too, didn't stop.
maybe when it's 5k i will have them take a look...
Old 05-07-15, 11:27 AM
rominl
exclusive matchup
rominl's Avatar
interesting. it does sound like a stuck cd when you try to eject it (but i didn't push any button). the cd plays just fine. and you can also say it's like a spinning fan that catches something for few seconds
Quick Reply: buzzing sound around the radio / cup holders?
