Brake Pad
Old 04-10-15, 07:50 AM
alamoudim
9th Gear
alamoudim's Avatar
Default Brake Pad
Hi,
i am new here, i am planning to change my GS350 OEM brake pads, and would like to get some aftermarket ones, i am not sure which one to take (powerstop or akebono) i am looking for low dust low noise one.
can you please help me with your experience
p.s i am not sure if this s even the right place to post.
Old 04-10-15, 08:26 AM
mrpartsman
mrpartsman's Avatar
Akebono is your best option for no brake noise or dust, they are one of the best pads I have ever used and sold.
Old 04-10-15, 08:35 AM
ItzFilyO
ItzFilyO's Avatar
Received 1,046 Likes on 661 Posts
Do they make one for the RWD FSport bigger front brakes too? How much are they?
Old 04-10-15, 10:31 AM
alamoudim
9th Gear
alamoudim's Avatar
Thanks. But from your reply i can understand the powerstop has something special? Do they?
Old 04-10-15, 06:54 PM
sam430
sam430's Avatar
Are these the ones for 2013 and above GS?
Akebono ACT1118 ProACT Ultra-Premium Ceramic Brake Pad Set
Old 04-10-15, 09:43 PM
alamoudim
9th Gear
alamoudim's Avatar
Akobane has both front and rear. The only thing i dont like about them is that they dont make the sport high perf. One?
What is ur car model and year
Old 04-10-15, 10:18 PM
ItzFilyO
ItzFilyO's Avatar
It's a 2014 GS350 FSport RWD. Mine has bigger front brakes than normal GS or AWD FSport.
Old 04-11-15, 09:18 AM
mrpartsman
mrpartsman's Avatar
The power stops are OK pads, I dont think the quality is there as the Akebono, thats y Akebonos price is so much higher, u get what u pay for.
Old 04-11-15, 09:22 AM
mrpartsman
mrpartsman's Avatar
all the GS front pads are the same which is ACT 1118 and the rear ones are ACT 1391.
Old 04-11-15, 06:15 PM
ItzFilyO
ItzFilyO's Avatar
The bigger RWD FSport front brakes have the same pads as the regular GS?
Old 04-11-15, 10:14 PM
dchar
dchar's Avatar
They don't have the same part number as the regular GS pads. I remember asking service advisor if cheaper pads I saw on Sewell (RIP) was correct, and he said they wouldn't work on my F-sport because they were for regular GS. He gave me the part number for the F-sport ones, so I assume they are different in size.
Old 04-11-15, 10:36 PM
ItzFilyO
ItzFilyO's Avatar
I'm going Akebono for my next pads cause I can't stand the dusty OEM pads. They're crazy dirty man! But I need to know which Akebono pads fit the larger FSport brakes.
Old 04-20-15, 01:29 PM
Stitch626
Stitch626's Avatar
i bought and installed the Akebono ones since i had them on my 3IS F Sport and for some reason they are screaching and we have no idea why? Can anyone help understand or offer a fix if not im going back to stock pads!
Old 04-20-15, 11:44 PM
sarmyth
sarmyth's Avatar
Hey, same issue here with my 4GS F Sport. I've had them on for ~2k miles now and they seem to squeal less, but that may be just because its getting warmer.
I've noticed they only squeal for the first 2 stops in the morning, quiet after that.
Did you happen to use the akebono backing plate or did you put the stock lexus one on the back of the akebonos? I used the akebono plate but have been considering pulling them for the OEM Lexus one as it's textured and is only a 1/2 plate; I've been guessing that may control the squeal...
Old 04-21-15, 06:31 AM
jonathanz
jonathanz's Avatar
so does RWD come with BIGGER caliper or just bigger Rotors? if same size calipers then they share same part # for pads with AWD.
Quick Reply: Brake Pad
