Changing the door welcome courtesy light.
Old 01-06-16, 05:04 AM
  #91
organa7
organa7's Avatar
It was pretty fun that I went to Atlanta for the weekend right after putting them in the front doors. And sure enough when coming out of a club and opening the door for my girlfriend at the vallet station heard several "cool" and "wow" comments.
Also Here is a quick look of it on both doors.
Old 01-07-16, 06:51 AM
  #92
Sevn86
Sevn86's Avatar
Originally Posted by 1fuzzybk
Just ordered mine. They are coming on the slow boat from China...
I ended up pulling the trigger on these yesterday. Spent $35 for the set and I'm super excited. Can't wait to install these. Hopefully they arrive soon as mine are also coming directly from China.
Old 01-11-16, 07:17 PM
  #93
Dbaliko
Dbaliko's Avatar
Originally Posted by bclexus
THESE appear to have the exact same 'crisp' projector and looks just like what I originally bought from Michael Albayati at BMWLED/FirstAutoLED. They are the newer style without a circle around the entire projection. I believe they are one-in-the-same as what I have...
And THESE appear to be the old style with a circle around the entire projection.
And THESE, which also have a circle around the entire projection.
Thanks for this. Ordered mine today.
Doug
Old 01-11-16, 09:46 PM
  #94
EyeKutr
EyeKutr's Avatar
Got mine installed tonight, I had to open them up and reaim the projector really. Driver door needs to be more forward and in towards car, same with passenger but in the opposite orientation to the housing. Also the sharpness can be adjusted by pulling out the projector from the LED source. Experimentation will get you good results.
Old 01-12-16, 02:24 PM
  #95
Lexed350
Lexed350's Avatar
Originally Posted by dinachroek
okay i just finish. it was pretty easy. thank so much !!
I got the same thing. Did you pry it loose on the sides or top/bottom?
Also, would there be any warranty issues with Lexus by replacing with this aftermarket part? Thanks.
Old 01-12-16, 08:05 PM
  #96
Sevn86
Sevn86's Avatar
No warranty issues as it's just a plug and play mod. Your not modifying the wiring and so I don't see it as an issue with Lexus.
Old 01-12-16, 11:16 PM
  #97
onexcite
onexcite's Avatar
I got them for my front doors but I hate that they cut off after 15 seconds. I contact the vendor and he told me it was design like that for preventing overheat purpose???
Old 01-13-16, 08:39 AM
  #98
puffdaddy
puffdaddy's Avatar
That's BS. Mine stay lit for 2:00 (then will blink and go out). Which ones did you get?
Old 01-13-16, 11:03 AM
  #99
Sevn86
Sevn86's Avatar
I ordered what looks like a diifferent version then what most of yall have installed. I never thought to look to see how long there suppose to stay lite. I was under the impression that the lights would stay on as long as you have the door open. I didn't know there was a timer built into them.
Old 01-13-16, 05:34 PM
  #100
onexcite
onexcite's Avatar
I got mine from ebay First Auto LED / BMW led store from California back in 2015. After that they close down their ebay store.
Old 01-13-16, 05:38 PM
  #101
onexcite
onexcite's Avatar
I'm looking to replace mine with this dual color:
http://www.ebay.com/itm/151704272685?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Anyone experiences this version of door lights?
Old 01-14-16, 09:15 AM
  #102
Prinny
Prinny's Avatar
Sounds defective ... might have to buy new ones. 15 seconds is much too short.
Old 01-14-16, 11:07 AM
  #103
bclexus
bclexus's Avatar
Received 1,996 Likes on 1,418 Posts
My driver's side door welcome courtesy light stayed on for 87 seconds the first time I tested it. I then immediately re-tested it again and it stayed on for 70 seconds. The third time it stayed on for 65 seconds. The passenger side door welcome courtesy light stayed on 91 seconds, 67 seconds and 61 seconds respectively. The ambient temperature at the time of the test was 71 degrees.
The simple self-contained circuitry in the courtesy light (that is designed to turn Off the light after 'x' seconds) probably does not have close tolerance (high precision) components for accuracy, nor adjustable thresholds for tweaking of the timing...simply because it is not particularly important how long the door courtesy light stays On as long as it stays On for around 60-90 seconds. I'm sure each brand door courtesy light uses a slightly different circuitry design and/or components, which will produce different timing as well.
Old 01-14-16, 05:27 PM
  #104
Sevn86
Sevn86's Avatar
I got mine in this afternoon and just installed them 15 mins ago. I actually started to adjust the direction on one of them and after about 2 minutes they turned off themselves. Also I noticed the projection assembly or whatever it's called gets kinda hot. I think that's why they have timer built into them I think.
Old 01-14-16, 05:46 PM
  #105
Lexed350
Lexed350's Avatar
Care to post a picture on how it turned out? Thanks
Quick Reply: Changing the door welcome courtesy light.
