question about PSI on aftermarket wheels
Old 07-28-14, 02:54 PM
Sosodef79
Sosodef79's Avatar
Default question about PSI on aftermarket wheels
Just got my wheels put on and I'm not sure what the PSI is supposed to be.
My Specs are
245/35/20
275/30/20
My wheels are 20x9 in front 20x10.5 rear.
I have Sumitiomo HTR Z III. The tires themselves say 50PSI MAX. The guy at the tire shop said he put it in the computer and it told him to put:
31 in front, 33 in rear. When i went to get my alignment today they put it to 40PSI before alignment. How do i verify what is the correct pressure?
Thanks for any help!
Old 07-28-14, 03:27 PM
yardie876
yardie876's Avatar
I asked my shop about this and they said to fill them up with the same manufacturer psi specs listed on the door jam.
Old 07-28-14, 03:32 PM
SNiiP3R
SNiiP3R's Avatar
You are running low profile tires now, so the more pressure you put the more protection you will have. 38 - 39 psi is good enough. With your specs, I personally would not run anything below that.
Old 07-28-14, 03:38 PM
Sosodef79
Sosodef79's Avatar
Aren't the door jam specs based on the stock rims and tires?
Old 07-28-14, 03:53 PM
Sosodef79
Sosodef79's Avatar
What's up man thanks for your input. Weren't you running the same wheels? Vssx step lip wheels?
yardie876
yardie876's Avatar
That's what I asked them too and they told me to maintaining that pressure is fine. I'm running 37 in the front and 38-39 in the rear cold.
Old 07-28-14, 04:31 PM
Sosodef79
Sosodef79's Avatar
Cool thanks for your help, Looks like most peeps are running about 38 here.
Old 07-28-14, 06:36 PM
KB350
KB350's Avatar
I'm running the same size tires you are except they are Hankooks and Discount Tire Direct told me 37 front and 36 rear and have had no problems and a smooth ride.
Old 07-28-14, 08:47 PM
JEFFOS69
JEFFOS69's Avatar
You're fine with 40 - personally I would probably run in the 43-45 if your max is 50. Better mpg and better handling than having softer tires due to lower psi
Old 07-29-14, 08:57 AM
LexRuger
LexRuger's Avatar
I'd do low 40s. Make sure you air them when the car is cold.
Old 07-29-14, 01:33 PM
Schmexus
Schmexus's Avatar
I run 30-32. The ride is too rough any higher. Mid 40's is crazy. I couldn't imagine how rough that must ride on these cars?? Especially with low-pro tires.
Old 07-29-14, 01:55 PM
LexRuger
LexRuger's Avatar
With plus sized wheels, the tire's sidewall is shorter so the rim is closer to the ground. Higher PSI makes the sidewall stiffer which can reduce damage from potholes.
Old 07-29-14, 02:03 PM
Schmexus
Schmexus's Avatar
Making an already stiff sidewall even stiffer makes a rough ride. We don't have potholes out here so I guess I'm more worried about ride comfort than wheel damage.
Old 07-29-14, 02:31 PM
LexRuger
LexRuger's Avatar
Nothing wrong with that
y2tony3
03-12-16 10:43 AM
hube
09-26-15 11:17 PM
DaVeyBoyTX
11-04-13 03:00 PM
Aristo300
Wheels, Tires & Brakes Forum
15
03-25-08 11:21 PM
cmc07e
04-16-07 12:07 PM
Quick Reply: question about PSI on aftermarket wheels
