TRS LED Fog Light Install
Old 07-13-14, 04:58 PM
BailsVT
BailsVT's Avatar
Default TRS LED Fog Light Install
I went to Atlanta a few weeks ago. While I was down there I stopped by TRS and picked up a set of their new LED fog lights. I met Matt and got to check out his GS, which looks even better in person. I used mso4's detailed instructions to do the install so I will only point out what I did differently. Here are all of the parts you need to do the install.
Tools: phillips and flat head screwdriver, 10 and 12mm sockets and ratchet, wire grabber, wire cutters/strippers, wire crimpers, and a utility knife.
The lights are high quality and come with H11 plugs that snap onto the wires on the lights. Use needle nose pliers to pull the wires from the inside of the plug once you get them started by hand. This will make it easier to get them to snap into place. The lights are also adjustable and have the same mounting points as OEM.
Installing the lights wasn't bad, and it only took about 4 hrs. As ms04 noted, the hardest part is tapping into the parking light wire under the dash. Here are some pictures from the install.
Relay mounted and wired
Battery connection
Passenger side plug
Instead of running the wiring for the driver side along the bottom of the bumper, I ran it across the top of the metal bumper and zip tied it to the parking sensor wires. You have to remove the panel pictured below to get the wires through the opening.
Fog light harness
When I installed the first light I thought no way this will fit, it's too big. Make sure the top inner tab on the light is inserted into the cutout in the bumper. After you do this the light will fit like a glove.
Light installed
Light w/ Bezel
Switch wire (hidden)
You have to cut or puncture the grommet to run the switch wire into the car. If you look under the dash you will see a small hole in the grommet that sits above the wires off to the right. Put a phillips screw driver that is slightly larger than the hole into the hole in the grommet, and push until it stops. There will be a protrusion on the grommet when you look at it from under the hood. Cut an x on the end of it with a utility knife. Remove the screw driver from the hole and force the wire grabber through the hole into into the engine bay.
Switch wiring
Switch
Install done
The lights are really bright and make there presence known when driving at night. I will post pics with the headlights on and of the cut-off next week after i adjust them.
Old 07-13-14, 07:00 PM
bigblack06
bigblack06's Avatar
Is it me or are there no pics showing!
Old 07-13-14, 07:27 PM
BailsVT
BailsVT's Avatar
If you right click the pic link and open it in a new tab it will open, I don't know why they didn't embed in the post. I'll try to fix them tomorrow. Anyone else had this problem using pics from google drive?
Old 07-14-14, 06:42 AM
GregCanada
GregCanada's Avatar
Nice find, these look plug and play for models that come with OEM fog's. Definitely putting a set on my wish list.
Old 07-14-14, 07:20 AM
ItzFilyO
ItzFilyO's Avatar
Received 1,046 Likes on 661 Posts
That's most likely cause it's a secured site, try using Photobucket.
Old 07-14-14, 07:24 AM
bigblack06
bigblack06's Avatar
Thanks that worked, they look good.
Old 07-14-14, 08:05 AM
BailsVT
BailsVT's Avatar
Pictures are fixed courtesy of life hacker. Here is the article that tells you how to embed photos from google drive: http://www.lifehacker.com.au/2013/02...-google-drive/
Old 07-14-14, 01:22 PM
sam430
sam430's Avatar
how's this compare to the OEM LED from sewell?
Old 07-14-14, 01:36 PM
mso4
mso4's Avatar
Clean install looks great!!
Old 07-14-14, 01:51 PM
RTIS250
Yes. I drove the LFA.
RTIS250's Avatar
Whats the cost on the kit? Looks pretty good!
Old 07-14-14, 02:06 PM
wickedap1
wickedap1's Avatar
Looks good! Very clean install.
Old 08-03-14, 03:37 PM
BailsVT
BailsVT's Avatar
They are plug and play for OEM and would be a quick and easy upgrade.
Originally Posted by TRSMatt
Looks great man! thanks for taking the time to do this write up. I actually got a PM from Greg today about the Fog Lights - and depending on how many people may be interested we can probably get a group buy discount on them for everybody. They are indeed a perfect fit for the 4G GS, are essentially the same thing as the OEM LED Fog Light option thats now available on the 14+ model years, just for about $400 less!
No prob man.
I prefer these over the OEM LED. The light comes out of the entire lens and is focused using optics that are within the housing, vs the OEM lights that have a rectangular opening that light light comes out of.
Thanks, good instructions made the install easy.
Thanks. The lights came from TRS ($175) then the rest of it was pieced together. The harness, bezels, and misc parts costs about $130.
Thanks
RDAK96
Performance & Maintenance
05-04-19 06:53 PM
Mesh704
10-15-14 02:55 PM
xshurikx
SC- 1st Gen (1992-2000)
01-03-14 12:53 PM
ddb
10-11-13 08:17 PM
Quick Reply: TRS LED Fog Light Install
