So i got some wheels but seems to agressive?
Old 05-15-14, 06:38 PM
ilv1004s
ilv1004s's Avatar
Default So i got some wheels but seems to agressive?
Hey guys i got some wheels for my new GS that i bought 2 days ago
but the wheels seems abit too agressive for the rear
the wheels specs are
19x8.5+15 offset
19x10 + 15 offset
all on standard F sport suspension
what do you guys think
Old 05-15-14, 06:57 PM
mrpartsman
mrpartsman's Avatar
can u post some pics , so we can see, but with those specs u should be fine and is ur car lowered or no.
Old 05-15-14, 07:05 PM
ilv1004s
ilv1004s's Avatar
oh ok cool
its on factory F sport suspension but im planing to lower the car with RSR's or Teins
Old 05-15-14, 09:14 PM
LexFather
Guest
Posts: n/a
That is very aggressive you will have to camber the car in.
Old 05-15-14, 09:26 PM
Dukeaudio
Dukeaudio's Avatar
Agree...along with a huge tire stretch.
Old 05-15-14, 10:17 PM
jmtamu
jmtamu's Avatar
Extremely aggressive.
Old 05-15-14, 11:32 PM
tungo
tungo's Avatar
You're fine with a fender roll in the rear and stretched tires and not a major stretch. 255/35/20 should work fine or even a 265/30/20. My stock wheels with 25MM spacers on the front and rear pushing the wheel to +15 all around on BC coilovers does not rub at all except on full lock and that's if I do a fast full lock. Regular full u-turn and I am fine. Aligned with natural camber already and zero toe and I don't rub. I'm also on the stiffest dampening setting and my spring rate is 12K front and rear.
Keep in mind that wheels are 1/3 of the entire setup when it comes to fitment. You also have to consider tire brand and size as some are true to size, while some tires run narrow and others are fat. Last, you have to dial in your alignment. If you can get all three within a good range, you won't have problems.
New wheels I ordered are 20x10 ET18 and 20x11 Et22. That's gonna take a little bit of work to get it to fit, but I've seen it done and it can be achieved. The 4GS is a mid to high offset car, but any offset in the 30's-40's and your wheel well will swallow the wheels and make them look sunk in.
Old 05-16-14, 10:46 AM
sam430
sam430's Avatar
What wheels?? I'm looking for a few mm poke to show off the lip.
Old 05-16-14, 02:33 PM
tungo
tungo's Avatar
3 piece forged wheels
Old 05-16-14, 02:47 PM
NXXT
NXXT's Avatar
Similar to the specs Tungo mentioned. Anything can be done with work!
Old 05-16-14, 02:50 PM
sam430
sam430's Avatar
What's the wheel spec and how much camber?
Old 05-16-14, 04:28 PM
poorbong
poorbong's Avatar
+1 that is aggressive and itll look 4x4 without proper drop.
Old 05-16-14, 04:34 PM
SNiiP3R
SNiiP3R's Avatar
I think those are perfect offsets if you're going with air suspension. If you're going static, then you'll have to drive slammed to make these work and look good.
Old 05-17-14, 10:07 AM
ilv1004s
ilv1004s's Avatar
yeah i gave up on these wheels
i fitted them on
poked out around 2cms
Old 05-20-14, 06:46 PM
GSTONY
GSTONY's Avatar
Size is fine I'm running 19x 9.5 +22 front and 19x 10.5 rear +22
Quick Reply: So i got some wheels but seems to agressive?
