DIY Trunk LED Light Strip Guide
Old 05-02-14, 03:58 PM
Dukeaudio
Dukeaudio's Avatar
Thx AL13NV8D3R...just did mine, best sub-$15 upgrade so far. Took me a little longer since i made a small cut-out in the base plate for the wire. I wrapped all the excess wire and placed in the light compartment, then snapped the light cover back on. Huge difference!
Old 05-02-14, 07:22 PM
AL13NV8D3R
AL13NV8D3R's Avatar
Your Welcome! Why not post some picks of that nice a.. umm trunk. I love my car ****.
Old 05-02-14, 09:39 PM
Dukeaudio
Dukeaudio's Avatar
Did my best to route wire cleanly from the light compartment. Velcro'd vled's near subwoofer to direct light deeper into the trunk to avoid glare.
Old 08-02-14, 04:44 PM
gqinxs
gqinxs's Avatar
do you have a link for the vled and connector you used for this mod?
Old 08-03-14, 11:23 PM
mikec78
mikec78's Avatar
I think these are the links:
(but I can't seem to find the 24" strip, they just have the 36" strip)
** I wanted to do this mod also and had to dig around the site though I am not sure if these are the right ones ** = If someone can validate the links that would be helpful!
LIGHT STRIP:
http://www.vleds.com/accent-lighting...te-5k-led.html
ADAPTER:
http://www.vleds.com/accent-lighting...r-194-t10.html
Old 08-04-14, 05:30 AM
Nelexus88
Nelexus88's Avatar
I used a 20" light bar for my ES trunk light upgrade. http://www.oznium.com/smd-bar
Mounted it right behind the stock trunk light. Fabricated a connector to fit the OEM light socket (bulb removed) and extended the wires to the light bar.
The 30 LEDs do a very good job of illuminating the trunk and it looks like a clean factory installation.
Old 08-04-14, 05:38 AM
AL13NV8D3R
AL13NV8D3R's Avatar
http://www.vleds.com/white-6k-interior-strip-light-striplight-3-chip-36-led-24-inch.html
LIGHT STRIP:
ADAPTER:
I am the original poster of this thread and these links above are correct. My old link seems to be broken. Anyways here is another link for people who want a short light strip. I cant seem to fime the 5000k color version of these strips there maby vled discontinued them? But I prefer the look of 5000k.
Old 08-04-14, 11:48 AM
mikec78
mikec78's Avatar
Here is a 5% off coupon code:
VLEDS8SJ
It can only be used on one order (from what I have found).
Enjoy!
Old 08-04-14, 11:53 AM
TaninAuto
Sponsor
TaninAuto's Avatar
We have the pure white 6000K (no yellow tint and no blue tint) LED strips in stock. We can include the adapter with your purchase (any length adapter you need), can make the strip LED any length you need to the inch, and will also beat any price of any competitor.
Give us a call or send us a message.
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
Old 09-16-14, 09:25 PM
tknx
tknx's Avatar
Sorry to resurrect this thread, but what is the width of the LED strip so I know what Velcro to order? Will 3/4 inch work best or another size?
Old 09-17-14, 05:17 AM
AL13NV8D3R
AL13NV8D3R's Avatar
I just simply cut the velcro to the same width as the led strip. So basically I cut the velcro lenght wise then I cut the velcro width wise. Then I cut that in half to facilitate an easier install. But if I had to guess the width of that led is about 3/4 inch.
Old 09-20-14, 10:33 PM
tknx
tknx's Avatar
Ok, awesome. Did this today and it really does light up the trunk nicely. Super easy to do.
Man, I wish there were more mods that were this easy to do...
Old 09-21-14, 06:38 AM
mryeh17
mryeh17's Avatar
Thumbs up
Just did this yesterday with the parts from VLED. Took all of 15 minutes, so many thanks to AL13NV8D3R for the instructions!
The one thing I added was drilling a 7/32" hole through the light cover so the wire could travel easily.
Here are some photos:
7/32" hole drilled into cover. Velcro I used in background, cut in half and fit light strip perfectly
Result after installation, nice and neat
Old 11-03-14, 07:37 PM
popping
popping's Avatar
First mod I did. What a difference. Never thought of doing it this way, normally just put a bulb in. Thanks
Old 11-07-14, 10:04 AM
tedbird
tedbird's Avatar
I installed SMD12 board from Diode Dynamics:
http://www.diodedynamics.com/store/l...runk-light-led
It fits inside the trunk light fixture utilizing a bulb adapter. Bright as can be - clean and easy install!
tejanp (04-14-17)
Quick Reply: DIY Trunk LED Light Strip Guide
