Awd Exhaust
Old 03-02-14, 02:36 PM
0mghi2u
0mghi2u's Avatar
Default Awd Exhaust
Wsup Guys. I currently have the Invidia axle back on my gs f sport awd. I want the rest of the exhaust but since Invidia is being very unhelpful for us awd ppl I wanted to see what the main difference is between the rwd and awd full catback exhaust piping? Like is it just the back axle part that makes it so different ?
Old 03-02-14, 04:11 PM
SNiiP3R
SNiiP3R's Avatar
No, the back portion is the same. And I'm 90% positive that the middle pipe is the same. However, the 3rd piece that goes into your engine is different, but not by much. At first glance you won't see the difference, but if you look closer you will notice that the left pipe is shaped slighty different. I will post pictures later
Old 03-02-14, 04:30 PM
SNiiP3R
SNiiP3R's Avatar
Here is the closer look,
This is very doable, I'm sure JoeZ or Invidia can make something for us. Since it's only 1 pipe that has to be changed. They dont have to modify the entire design.
Old 03-02-14, 04:35 PM
0mghi2u
0mghi2u's Avatar
Wonder if I got the rest of the Invidia exhaust pieces I can't get the mid portion bolted on and leave the mien front ones oem.
Old 03-02-14, 04:36 PM
0mghi2u
0mghi2u's Avatar
Thanks man
Old 03-02-14, 04:38 PM
SNiiP3R
SNiiP3R's Avatar
I think that will work, like I said I'm only 90% sure but too me they look the same. So, if that works for you, please let us know!
Old 03-02-14, 04:44 PM
SNiiP3R
SNiiP3R's Avatar
Here is the RWD, if you compare it to the pictures I posted, you will see that they are practically identical
Old 03-02-14, 04:48 PM
0mghi2u
0mghi2u's Avatar
Your right everything but the front pipes look to be the same. Now only thing that screws me is unless I get the front section on Invidia cut off and welded to oe front pipes I wouldn't be able to install it. Fml
Old 03-02-14, 04:59 PM
SNiiP3R
SNiiP3R's Avatar
If this is how Invidia makes their mid pipes, then I think you can install the mid and front right pipes. Then for the left pipe you will use your OEM attached to Invidia mid ?
Old 03-02-14, 05:02 PM
0mghi2u
0mghi2u's Avatar
But the problem is the oem front pipes don't come off. Since they are once piece with the mid pipes. So unless it gets cut and welded to Invidia it wouldn't work
Or if I could find a shop to bend the pipe to fit. But that probably cost a arm and a leg doing both options fml
Old 03-02-14, 05:05 PM
SNiiP3R
SNiiP3R's Avatar
You're right, I forgot they are not 2 piece like the aftermarket....
Old 03-03-14, 05:17 PM
GSTONY
GSTONY's Avatar
Can easily get custom front pipe for the invidia for dirt cheap
Old 03-03-14, 05:28 PM
0mghi2u
0mghi2u's Avatar
Hmm from Where?
Old 03-03-14, 06:17 PM
0mghi2u
0mghi2u's Avatar
Ok now the questions
If I cut the end of the stock front pipe driver side and end of the driver side Invidia and got it welded would those toe metals weld together?
Would the sound still be same as having original Invidia mid pipe set up ?
Old 03-04-14, 08:03 AM
vietboix
vietboix's Avatar
Interested to know about this to! Catback system with small modification?
Quick Reply: Awd Exhaust
