Can trans default setting = Sport?
Old 02-10-14, 06:38 PM
revhigh
revhigh's Avatar
Default Can trans default setting = Sport?
Is there a setting to have the transmission default setting at startup = sport (or sport+). It seems the default is ECO.
Old 02-10-14, 06:57 PM
FishBike
FishBike's Avatar
There is not. Only normal and eco modes can be "remembered".
The reason is when emission and fuel efficiency tests are done, it has to be done in the most aggressive mode that can be set as a default. If Sport+ could be a default, they'd have to test it in that mode, and the test results would be worse.
Old 02-10-14, 07:07 PM
Nismo
Nismo's Avatar
Question
Sounds logical. Do you have a link to the EPA's fuel economy testing requirements? It would be interesting (a relative term, mind you) reading.
For anyone else, is there a workaround? A jumpered wire on the ECU (was able to do this on a Honda I once owned, but for a different reason), an ECU flash (rather not go this route), or some other method?
Old 02-10-14, 11:03 PM
sam430
sam430's Avatar
This is software issue. ...but, try this... Turn the **** and hold it. Start the car and see if it goes to sports mode. If it does, you can cross wires. I woudn't recommend it (if there is software updates, it might start to act weird). You can devise an electonic to pulse once after the cars initial startup (if you are lazy to turn the ****).
Old 02-11-14, 07:38 AM
Afrosheen
Afrosheen's Avatar
Has anyone checked with the dealer to see if they can set it? I know there are a handful of things they can reprogram, this might be one but may be "undocumented".
Old 02-11-14, 08:16 AM
yardie876
yardie876's Avatar
I remember a few people asked their dealers a while back and got turned down.
Old 02-11-14, 08:37 AM
sarmyth
sarmyth's Avatar
I haven't seen anything in the factory service manual documenting a setting like this, but i wish a performance company would chip our trannys. I'd love selectively firmer shifts instead of going for a permanent valve body modification.
Hermes
07-07-19 12:44 PM
enoren
02-19-17 05:28 PM
400to300H
ES - 6th Gen (2013-2018)
12-14-16 05:54 AM
proview3r
03-28-15 08:50 AM
dunebuggy
NX - 1st Gen (2015-2021)
17
02-13-15 02:01 PM
Quick Reply: Can trans default setting = Sport?
