Cruising Range did not update after a second fill up?
Old 02-02-14, 03:05 PM
SNiiP3R
SNiiP3R's Avatar
Default Cruising Range did not update after a second fill up?
I got to the gas station when I had about 50 miles left, so I decided to put $45. After the fill up the cruising range was showing 253 miles. I got out and decided to put more gas. I was able to put $10 w/ change, which was 2+ gallons. However, the cruising range never changed! It still showed 253miles, even after I turned the car off / on again. By the time I got home it was 250 miles.
I'm very surprised that the car did not see the 2 additional gallons....
Old 02-02-14, 06:30 PM
yardie876
yardie876's Avatar
Weird. I noticed the cruising range does not change until you actually put the car in gear and drive off. 2 gallons should be significant enough to show up.
Old 02-03-14, 02:34 PM
sgmstr
sgmstr's Avatar
maybe that 2 gallon did not trigger the sensor in the gas tank or may be a timing issue (i.e. you filled gas within a minute the range was updated and the sensor may have thought it updated already, etc...), but regardless it should have updated after a while at least.
Where is this sensor by the way? is it by the gas cap or inside the tank?
Old 02-03-14, 03:51 PM
FishBike
FishBike's Avatar
Pretty sure the only sensor involved is the same fuel level sensor that drives the fuel gauge. When you turn on the ignition with significantly more fuel in it than when it was shut off, it refreshes the range calculation. There's a note in the manual that it won't do that if you only add a "small" amount of fuel, or if the ignition is on while refuelling. How much a "small" amount is, isn't defined.
SteveCanyo
HS 250h Model (2010-2012)
07-19-18 08:12 AM
Benjam1n
05-06-17 06:18 AM
Femel
RX - 1st Gen (1999-2003)
06-20-11 09:50 AM
305ls400
03-09-11 07:46 AM
kgh31386
GS - 1st Gen (1993-1997)
10-04-05 08:57 AM
Quick Reply: Cruising Range did not update after a second fill up?
