Installed My LED Turn Signals.
I got to install my LED turn signals with the adapter. I purchased the adapter from ijdmtoy and the led turn signals from vleds. The only issue I had was the fitment, since I was told by ijdmtoy that the plug is universal so required to fixing up. I have posted some pics of the adapters before and after being cleaned up, hopefully this helps as there is no wiring cutting and the flashers work perfectly.
Old Bulb
LED Turn Signal
Old Bulb
LED Turn Signal
Old Bulb
Video Link: https://www.youtube.com/watch?v=si7WMSJHh2Q
LED Turn Signal
Video Link: https://www.youtube.com/watch?v=iT_ybMCJOS8
Old Bulb
LED Turn Signal
Those plug and play extender (LED decoder) with resistor are not working. You'll need external resistor to cure the hyper flash. You can cut off the black box resistor and replace with external resistor will work. Or get the V3 Triton and forget about the bulky hot resistor. Also those socket take some dremel to fit to GS housing.
Although I agree with you that the GS is expensive enough to warrant a full LED package that would include every bulb used including the turn signals, I look at it as another "cool" mod to be able to do to fill out our enthusiast pastimes
