Old 01-09-15, 12:24 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Brake Guides
Print Wikipost
need to replace drivers side F sport brake caliper cover. Advice?
Old 08-02-13, 12:57 AM
ARB5
ARB5's Avatar
Default need to replace drivers side F sport brake caliper cover. Advice?
I need to replace a GS350F front caliper cover that the was painted red. Any advice to replace this piece without buying a 4-pc set? It was nicely painted and I don't see anywhere to buy these in red with the F Sport lettering. I would prefer not to change the color as these covers got me the second I saw them at the dealership. I bought it used and the previous owner did these right. Apparently blue is stock??? Not sure..
Thx
Thanks
Old 08-02-13, 02:37 AM
Igor911
Igor911's Avatar
Unfortunately, calipers typically comes as a full set...unless you go aftermarket
Old 08-02-13, 07:08 AM
bigblack06
bigblack06's Avatar
Thx
Thanks
I'm a little confused, do you want to change the color or do you want to replace the caliper because of a problem. A pic would help as it sounds like you just want to change the color, which you could just paint over it with another color, also stock color is not blue its more like dark graphite.
Old 08-02-13, 08:50 AM
dchar
dchar's Avatar
You can buy some brake caliper decals that say f-sport on them and put them on your currently red calipers. This will be much cheaper, only like $8-10. And f-sport calipers are gray when stock, not blue.
Old 08-06-13, 09:20 PM
ARB5
ARB5's Avatar
Thx
Thanks
Thanks for the input. The red caliper cover keeps coming loose after hitting pot holes on these messed up LA freeways. My mechanic has tightened it down but stated the covers are not necessary and suggest it be taken off. I'm a novice and didn't know you can paint these, also I heard that the covers protect the rims from damaging break dust. When I first wrote this, I was trying to find a replacement and ones that will stay on, not coming loose. Thanks again and interested to hear any thoughts!
Old 08-06-13, 09:33 PM
e39ng
e39ng's Avatar
If I understand correctly, are you having something similar to this but with Fsport letters?
Old 08-07-13, 04:23 AM
bigblack06
bigblack06's Avatar
I think we all need a pic of this, if they are the covers pictured above they can not be painted over. I would suggest taking them off if that's what they look like.
Old 03-11-14, 11:20 PM
ARB5
ARB5's Avatar
Thank you to all who replied to my post I left vacant for all this time. I wanted to post a lousy picture of the caliper paint job that I had done (I'll probably post a better one) on my 2013 350 F. I think they came out really cool minus some small blemishes and maybe a bit too much clear coat over the drivers side decal, it was getting dark. A big thanks to Dchar for the mention of the decals. I got them for $10 online. And they really pop! Didn't go the powder coat method ( would have preferred ) instead used VHT 7030 spray paint (or similar) red caliper paint, the decal of course and VHT clear coat to go over. I did some research and some guys had good things to say about this paint and not such kind words of some other paints, especially he brush on method. Pretty stoked at the look and we'll see how it holds up. The question is now: should I paint the rear calipers or leave the red F Sport cal covers that are on there? They actually look ok but I feel like its kind wussy. My gut tells me paint the rear too, any thoughts?
Attached Thumbnails need to replace drivers side  F sport brake caliper cover. Advice?-image.jpg
Old 03-14-15, 02:41 PM
GreentAzn
GreentAzn's Avatar
Would you mind sharing where you got it? I want it on my 2015 IS 350 F sport!
DocTLaw
03-23-19 09:14 AM
diggdyone
03-02-19 06:56 AM
g2bme
Suspension and Brakes
16
06-24-17 05:08 AM
GBFSport
01-23-15 11:08 PM
Asher
11-22-12 06:27 PM
Quick Reply: need to replace drivers side F sport brake caliper cover. Advice?
