Aftermarket Amp and Subwoofer Install
Old 10-18-13, 07:27 AM
Jump2man3
Jump2man3's Avatar
Looks nice!
Old 07-01-14, 01:10 AM
sam430
sam430's Avatar
Originally Posted by GS350F
My line out convertor has a built in remote turn on. So i used that one.
as for the subwoofer wires. They are number 6(red) - and 21(white) +
Do I need a speaker level input converter for these two lines ?
Old 07-01-14, 08:35 AM
LexRuger
LexRuger's Avatar
Originally Posted by Rozay604
That cap gotta go. No need to use that, waste of money
Originally Posted by 95bat
Nice looking box. You should research how much voltage drop is produced with capacitors and their actual capacitance. They're mostly cause more harm than good, get rid of it
This. I had a 1,000 watt rms MTX amp in my ES with no cap and there was barely any voltage drop at high volumes. If you want more peace of mind without the cap, you could do the "Big 3 upgrade".
Old 07-14-14, 12:21 AM
sam430
sam430's Avatar
What are the steps to run the wires from the battery to the rear? Do I have to remove seats to get it to the trunk?
Old 07-14-14, 06:21 AM
Rozay604
Rozay604's Avatar
Yes u have to remove the seat.
Old 07-14-14, 08:39 AM
LexRuger
LexRuger's Avatar
Under the door sills and under the rear seat. These parts just snap off.
Old 07-14-14, 01:04 PM
sam430
sam430's Avatar
Thanks. Glad major work is not necessary.
Old 07-14-14, 01:06 PM
sam430
sam430's Avatar
Ok....i guess i will find out. Just trying to get a sense of how difficult it would be.
Old 07-16-14, 03:52 AM
DaGou
DaGou's Avatar
I am sure it sounds so much better. I have been thinking of doing the same with a little different set up. I really do not want all that junk in trunk. I would like to build a custom box and attach it to the area where the shat sub woofer is now tucked out of the way. Any way congrads on your install and enjoy!
Old 07-16-14, 10:15 AM
sam430
sam430's Avatar
A pair of high powered 8" in a small box should do the trick.
Old 07-16-14, 06:54 PM
jayyyy
jayyyy's Avatar
i did my trunk recently. used digital design sub sundown amps. audison bit 10 processor and voce components and 1/0 wires.
Old 07-17-14, 08:38 AM
LexRuger
LexRuger's Avatar
Nice equipment. Is the sub firing through the ski hole?
Jazzkanda6
GX - 1st Gen (2004-2009)
11-07-17 06:57 AM
Toxicxk23
08-12-12 05:09 PM
pizitz70
01-04-11 08:38 AM
2NDGENLEX
12-23-09 08:40 AM
bigcory
07-02-09 07:38 PM
Quick Reply: Aftermarket Amp and Subwoofer Install
