4GS Fuel discussion Premium or Regular Gas? (merged threads)
Old 06-27-13, 01:38 PM
  #121
Mike728
Mike728's Avatar
I've alternated fill-ups on my 87 octane recommended ES, between 87 and 93. After 4,500 miles I've noticed absolutely no difference in power, or fuel economy between the 2 grades. I'll probably switch to 100% 87 octane soon and save the .45/gal.
Old 06-27-13, 04:52 PM
  #122
Received 2,499 Likes on 1,802 Posts
Originally Posted by zicogold
The Lexus tech rep talked about this last week and said yes Lexus does state running the RX and ES on 87 grade fuel, but he recommended 89 and even 91 grade. He said it was false economy, 87 grade fuel will yield lower hp and lower the exhaust system life. Of course if it is not your car, do what you want.
That just doesn't make any sense. The manufacturer reccomends regular, yes the HP is down slightly, from 272 to 268. I have had Lexus vehicles upwards of 12 years and 200,000 miles, and I have never had an exhaust system leak or perforation or any need to replace any component of the exhaust system, nor do you read about issues like that here in the forums for the older cars...so I'm not sure what "reduced exhaust system life" is. No mechanic will tell you to run premium when the car is designed for regular, and the ES and RX are designed for regular.
I had a 2010 ES, and it ran exactly the same on premium and regular. Same economy, same performance. The only difference was a fill up with regular was cheaper. Any difference is just a mental thing.
Old 06-27-13, 05:36 PM
  #123
ESsearch
ESsearch's Avatar
I too had a ES350 (2007) and ran regular in it when premium was specified. Just as SW13GS said, no difference whatsoever.
Zicogold would do well to avoid the Lexus tech he talked to. There is no way the grade of fuel can effect the exhaust system. Also, running a higher grade of gas than recommended is a total waste of money.
I run premium in my GS because the difference in price from regular is small and I drive the GS in a more "spirited" manner than I did the ES. I do believe however, that regular would not harm the engine at all.
Pete
Old 06-27-13, 08:27 PM
  #124
ECL
ECL's Avatar
This topic came up in a "know your car" presentation at my dealer this week. A couple of RX350 and ES owners were saying that 87 grade is ok to use. The Lexus rep said you can use 87 but the engine will knock (not a good thing) and you will get reduced horsepower and potentially greater fuel consumption. He recommended a minimum of 89 grade for their cars and 91 preferred. He then went on to say with the direct injection engines it is really not an option and 91 grade is the fuel to use.
Since 2012, Lexus has recommended 87 octane for the RX350.
Old 06-27-13, 11:21 PM
  #125
hopVIP
hopVIP's Avatar
I have always used premium in all my vehicles (its just a habit). And no matter what kind of vehicle it was when I ever went to regular for any reason the engine didnt like it as much. I tried to make a point earlier about preimum being a higher quality fuel and why it is better for an engine. Sticking with the engineeres recomendations is going to be the best. But, using premium will always benifit the engine (life wise and overall power and better operating quality, i.e smoothness, etc.). And if an engine is recommended to be ran on premium (a higher compression engine, as I have mentioned before) using a lower grade/octane fuel may not be damaging to it right a way but, the engine will not like it and eventually it will start to hate it. All I'll say is, if you care for your car and want to treat it with the best and pamper it and hopefully have it last a long time for you than take care of it. Give it what it wants and likes and it will give you the same. That's what I believe and my vehicles have always been good to me.
Old 06-28-13, 06:04 AM
  #126
Outrage
Outrage's Avatar
Retarded ignition timing can affect catalytic converter temperatures.
Old 06-28-13, 09:16 AM
  #127
zicogold
zicogold's Avatar
The Lexus rep did preface things by saying that the marketing material states 87 grade fuel because their competition advertises 87 grade fuel for their vehicles. He then paused and said but it will have impacts on the engine. I am just saying what said.
Both my friends, the auto engineer (Ford) and the chemical engineer (Suncor) have in the past corroborated what was presented by the Lexus rep. I realize this contradicts what is stated in the printed material, but I guess we make our choice and live with it.
You should have seen the look of confusion on the faces of the RX and ES owner in presentation.
Old 06-28-13, 10:48 AM
  #128
praetor
praetor's Avatar
Wow! So much controversy over a simple question. Good job Stew! LOL
Old 06-30-13, 08:26 PM
  #129
He's full of it. That same engine has been used in the Camry, Camry Solara, Avalon, Highlander with Regular fuel for years. Is he saying that the engines don't last as long in those vehicles as they do in a Lexus application? There is just no logic to that argument.
This is the fallacy. Premium fuel is not a "higher quality fuel", it simply has a higher octane rating. Its the same fuel. There is no higher level of quality or refinement.
You aren't going to hurt anything by running premium, if it makes you happy go for it...but the goal of this community is to provide factual information to the membership so they can make informed choices. The facts are:
1. The 3.5L V6 in the ES & RX application is designed to run on regular fuel as of 2011. Prior to 2011 it was designated to run on Premium fuel with slightly enhanced HP figures. This same engine is also used in several Toyota applications designated for regular fuel. As per Lexus and Toyota, running regular fuel is fine for this engine.
2. Premium fuel is not higher quality than Regular fuel. The difference lies in the octane rating, one is designed for higher compression applications and one is not. Using higher octane fuel in a lower compression engine does not enhance power or fuel economy.
Those are facts. If someone still chooses to use higher octane fuel in a vehicle that is not designated for it because it "feels" better thats their prerogative, but facts are facts.
Old 06-30-13, 09:29 PM
  #130
LexFather
Guest
Posts: n/a
Originally Posted by bob4256
What is the price difference per fill up with premium gas? Around $4?
If that $4 is an issue for you, then you shouldnt have bought a 50K car. Just my opinion
Irony overload
GS needs premium. Some new Lexus models don't. I used to track and complain about gas then I Grew up. As much as I love cars I walk and take the train/trolly tons.
There are some odd fuel requirements on some cars FYI.... It's surprising...
Old 07-03-13, 09:43 PM
  #131
XBimR
XBimR's Avatar
Those following this thread might find this article interesting:
http://www.nytimes.com/2013/06/30/au...osts-more.html
“As we continue to reduce the displacement of the engine, the customers’ expectations of the performance of the vehicle aren’t changing,” Doug Skorupski, technical strategy manager at Volkswagen of America, said. “So you have to run higher and higher boost pressures from your turbochargers, and as you do that, higher octane plays into it.”
Engineers have several tools to prevent engine knock, but there’s no cure-all. Knock sensors, which can signal the engine-control computer to delay the ignition spark when detonation is detected, inevitably cut back performance. Owners of cars that carry a premium-fuel recommendation can safely operate their vehicles with regular unleaded fuel; however, the engine will lose roughly five horsepower and one to two m.p.g., Mr. Skorupski said.
“You are reducing your fuel economy and your performance, but there is no detrimental damage to the engine,” he said.
Another increasingly common technology, direct fuel injection, sprays gasoline into the cylinder at high pressure; the cooling effect of the atomized gasoline helps to keep knock in check. In effect, direct injection tricks the engine into thinking it is running a higher-octane gas — up to four to six octane numbers, Rick Davis, a combustion specialist at G.M., said.
Putting regular-grade fuel in a car for which premium is required, rather than just recommended, is far riskier, experts say. “Under extreme driving conditions, the engines aren’t necessarily protected from degradation or damage if somebody used regular fuel,” Mr. Davis said.
Old 07-04-13, 06:35 AM
  #132
rjm
rjm's Avatar
2013 GS350 Fuel Filler Door: I'm guessing this means REQUIRED instead of RECOMMENDED?
Attached Thumbnails 4GS Fuel discussion Premium or Regular Gas?  (merged threads)-2013_lexus_gs-350_det_lt_63013_600.jpg
Old 07-04-13, 06:38 AM
  #133
Joeb427
Joeb427's Avatar
That's not good enough for some.
Old 07-04-13, 07:02 AM
  #134
Stew4HD
Stew4HD's Avatar
It goes to show that you can't fix stupid
Old 07-04-13, 09:09 AM
  #135
Yeah seems pretty clear to me LOL
Quick Reply: 4GS Fuel discussion Premium or Regular Gas? (merged threads)
