4GS Fuel discussion Premium or Regular Gas? (merged threads)
Old 10-08-14, 09:17 AM
  #226
jkeller
jkeller's Avatar
Originally Posted by SW13GS
I ran regular in my 2010 ES that called for Premium also, but I run premium in the GS. The GS is higher performance, direct injected...I paid a premium for the vehicle over a more economically minded purchase like an ES or Avalon...so I give it the fuel it asks for.
When the ES went from recommending 91 to 87, the HP went from 272 to 268. When I was working in South Dakota, Wyoming, western Nebraska some stations sold 85 octane gas. All of those areas were over 4000ft elevation.
Old 10-13-14, 12:23 AM
  #227
Rbradleysd
Rbradleysd's Avatar
I always used mid grade on my GS (89)
Old 11-20-14, 07:22 PM
  #228
sharmila19
sharmila19's Avatar
In New Jersey and Pennsylvania with an 2013 AWD can anybody tell me what milage per gallon I should expect? Will be driving mainly on route 78 to and from Pennsylvania to Jersey City- thanks
Old 11-21-14, 10:36 AM
  #229
AL13NV8D3R
AL13NV8D3R's Avatar
If you drive an fsport awd then you might get around 20mpg If you have the luxury version of the car you might get slightly better like 22mpg. This is combined mpgs. I get about 24mpg but i have a RWD luxury version with 8speed tranny.
Old 11-22-14, 11:09 AM
  #230
sick21
sick21's Avatar
GS disrespect.
Old 11-22-14, 01:31 PM
  #231
faifai83
faifai83's Avatar
Top Tier Premium (91), as specified on the gas cap. (e.g. Arco, Chevron, Shell, 76)
Old 11-22-14, 04:32 PM
  #232
99alta
99alta's Avatar
Speaking about Top Tier gas, Costco Canada has applied for top tier gas status! Where I live their premium is usually about 20 cents a gallon cheaper on a consistent basis.
Wonder if they will change suppliers? Or does their current supplier already deliver Top Tier fuel, but they just don't have the designation yet?
Old 02-24-16, 09:11 PM
  #233
Cathy
Cathy's Avatar
In the Toronto area, premium costs 75cents more than regular per gallon and you can now see why I am reluctant to be price discriminated against.
As long as engine knock sensor is reliable I see no problem putting in regular. How many times do you really get to use all that power in the engine when traffic jams are all over the place? I only put premium when I travel to the States where premium gas is priced more reasonably and I know I will be driving long stretches of highway without jams.
Old 02-25-16, 07:58 AM
  #234
MJA1951
MJA1951's Avatar
Premium in the Chicago area has jumped to at least 60 cents more and many stations are 90 cents to a dollar more here
Old 02-25-16, 08:15 AM
  #235
GregCanada
GregCanada's Avatar
Yep it is quite pricey for premium up here.
Costco as mentioned is awesome, 91 octane for 3 cents more than the neigbouring gas stations sell regular for.
If you notice in the states, some pumps have "93 octane" and some are "91 octane". and 91 costs more. this is because 93 octane in NY include 10-15% ethanol, where 91 octane is zero ethanol, which is better for your engine (long term) and you return better MPG. So you are not really comparing apples to apples.
Old 02-25-16, 09:32 AM
  #236
dman3626
dman3626's Avatar
Petroleum is at an overall low, I'm surprised this conversation hasn't died off by now. I do understand the varying prices regionally but gas in general is much less now that is has been or ever will be in the future. I like to think of using premium as cheap insurance for a complicated machine I've invested a lot of money into. Our 3.5 2gr-fse is a high compression motor, using regular will cause some minor pinging and/or pre-detonation due to the advanced timing our cars have. If I wanted to use 87 or 89 octane I would have bought a decked out Camry which has a lower compression 3.5 liter v6. ( FSE's 11.8:1 VS FE's 10.8:1) Just my 2 cents.
Old 03-06-16, 08:14 AM
  #237
Nismo
Nismo's Avatar
Lightbulb
Octane rating and ethanol content are separate things.
Before it leaves a refinery, every batch of gasoline has to meet certain technical specifications and pass several lab tests. Some of that testing is for octane--the measure of a fuel's ability to resist igniting prematurely in a spark-ignition engine. The octane rating of a fuel is based entirely on those lab tests, and the tests do not care what molecules (benzene, toluene, cyclohexane, butane, ethanol, etc.) are in the fuel.
Octane requirements change with altitude, so an engine that requires 93 octane at sea level may only require 91 at higher elevations. Customer don't want to pay for (and so refiners don't want to make) a higher octane fuel than what is required. The reason some stations sell 91 and others 93 is due to altitude, not ethanol.
The Renewable Fuel Standard (RFS) requires transportation fuel sold in the United States to contain a minimum volume of renewable fuels. The law is complicated, but in short what it means is that your gasoline may (and probably does) contain up to 10% ethanol.
Compared to clear gasoline (i.e. gasoline without ethanol), ethanol has a higher octane rating, a lower energy density, and it can damage components not specifically designed for it, such as the fuel system in many older vehicles. Because of ethanol's higher octane rating, it can be blended with gasoline to achieve a higher octane rating than the gasoline without the ethanol.
When the RFS first went into effect, refiners were making gasoline under the assumption that it would be sold without ethanol. Once blended with ethanol, however, the gasohol (E10 gasoline) actually had a higher octane rating than the minimum rating shown on the sticker at the pump. This is commonly called 'octane giveaway' and is obviously not the most economical way to run a business. Today, since almost all gasoline sold in the U.S. is E10, most refiners make a slightly lower octane gasoline than they used to, but once blended with 10% ethanol, the octane jumps up to the required spec.
Old 03-09-16, 05:05 AM
  #238
Bj(CA)
Bj(CA)'s Avatar
Costco premium all day...
Old 03-09-16, 05:21 AM
  #239
2Squared
2Squared's Avatar
I use Shell V-Power NiTRO+ premium gas in my GS
Old 06-22-16, 03:15 PM
  #240
islandbeef
islandbeef's Avatar
Interesting...
Quick Reply: 4GS Fuel discussion Premium or Regular Gas? (merged threads)
