Vossen CV4 Polished but....
#48
Do you have a version with about 8mm less offset so you can fit a 285/30/20 without any problems?
#50
I have a 10.5 wheel and the rear with 285 and I have absolutely no rubbing. My minor rubbing issue is with my front and I notice I rub just a hair when I am backing up and my wheel is turned. My tire rubs on the inside black plastic.
#51
Do you have F-Sport with rear steering? Also, I see your signature that you have Tanabe springs which does not drop as low as RS-R Down Springs.
#52
With that drop my clearance was so little in the rear and I could barley fit a finger at an angle in between the rear fender and tire.
#53
What are you wheel and tire specs?
#54
So my rears are 10.5 inch wheel with a +45 offset and 285-30-20. My fronts are a 9 inch wheel with a +35 offset and 245-35-20.
I knew I was going to be cutting it close on my tire selection with a drop but I rolled the dice because I wanted that extra tire.
#55
Did you ever figure out why your rear tires were rubbing?
Your rear wheel specs are the same as djpeakSD's (10.5 wide w/45 offset), yet he was able to get a 285 on there with no rubbing. I also noticed as I was review the data that there are a couple other Vossen users who have 285 installed on their wheels with no reported isses.
Interestingly, most (if not all) Vossen applications are all the same for this car, yet you were the only one lucky enough to have the rubbing issue reported.
Whether you are lowered on RS-R Down or super down springs, the travel of the rear tire into the fender well is the same so it would have still rubbed even on regular down springs given enough weight in the car.
Perhaps you were also shipped the wrong offset on the rear wheels just like you were on the front wheels?
Or perhaps the rear steer actually made a significant clearance issue?
#58
Sweet GS bro! Have you seen the white GS with the Lexon CF Kit and Rohana wheels? I forgot his CL forum name but next Lexus Owners of Guam meet n greet ill send the invite so we can check out you ride.
#59
There's that amazing VOSSEN customer service again. They helped me so much too. They are great and the wheels look amazing
monoglot
08-31-18 06:33 PM
Mayo
Wheels and Tires Classifieds
05-02-13 10:39 AM
Shibumi1
06-27-12 04:24 PM
