On to ACC mode
On to ACC mode
Does anyone know of a way to turn the engine off but keep accessory mode on without having to cycle through off, then back to acc? I've tried double pressing, long pressing, etc to no avail....
Dude, that is brilliant. I sometimes want to turn off the car but leave it in ACC mode too. I was hoping that if I stepped on the brake and pushed the button it would start the engine again but it shut the whole thing off.
exclusive matchup
hope it works. since 06/07 people have had issue with this and the procedure has worked on all those generations. hope it's still the same. i think it's especially useful when you are back in your garage and you want to shut off the car, but want to finish the call on the phone through BT
Here is how Lexus + Toyota with push button start working:
Engine running + gear at Neutral + button = engine off, ACC on.
Engine running + gear at Neutral + button = engine off, ACC on. Gear still at Neutral if depress the brake + Start button = Engine start.
Engine running + gear at Neutral + button = engine off, ACC on. Shift gear to Park + depress the brake + Start button = All power off.
Engine running + gear at Neutral + button = engine off, ACC on. Shift gear to Park + Start button = All power off.
Option 1 good for people to finish the Bluetooth talking and process to option 3 or 4 to shut off the car completely.
Option 2 good for temporally turn off the engine and start the engine again. Ex: wife running inside while u crank up your music on ML.
Caution: The electronic parking brake may not engage if using any of these options.
I will be using Option 2 a lot. Wife always seems to need to pee as soon as we get in the car.
revhigh
12-05-13 07:52 PM
jkutti2000
ES - 5th Gen (2007-2012)
12
03-28-10 02:34 PM
