DIY puddle light led
#62
Will this bulb work/fit for GS? I see a lot of people using it for IS.
http://www.vleds.com/6k-white-4-led-...58-1-pair.html
Thanks.
Thanks.
#63
Thanks.
Thanks.
That bulb did fit in Lexus puddles on most if not all models the last few years.
I had those bulbs in 3-4 models and will be in my GS puddles soon.
I have those bulbs in my door panels
Vleds seems to be out of stock on those bulbs,though.I have 2 pair on back order.
#64
I am going to order a pair and replace my puddle light.
FYI, these bulbs are currently in stock.
Does anyone know what kind of bulb is used for the trunk light? Thanks.
VLEDS is back carrying the same smaller 4 LED flanks again which is great news.
I had those bulbs in 3-4 models and will in my GS soon.
#65
OUTPUT RATING: 5
5K WHITE 4 LED 2 WATT HP FLANK BULBS 194 168 158 | 1 PAIR B/O 152 158 159 161 168 184 192 193 259 280 285 447 464 555 558 585 655 656 657 1250 1251 1252 2450 2652 2921 2825
$14.99 Out of stock
Learn More | Add to Favorites | Add to Compare
I have two pair on back order for two months.I just emailed and asked when the bulbs will be available.
As far as the trunk you can go with this if you want bright but out of stock.A LED panel is good too.
http://www.vleds.com/5k-white-4-led-...58-1-pair.html
I went with this but not very bright but white and may change it.I just wanted to get away from the yellow stock bulb.
http://www.vleds.com/5k-white-high-p...58-1-pair.html
#66
Top Pretend,I just got an answer to my email on those bulbs availability.
We are very sorry for the delay of your order. We are currently in full production, and many of
the items are very close to being finished. Unfortunately it is taking longer than expected. We
hope to have all backorders filled by the first or second week of July, if not sooner. Once your
items are finished we will email you a shipping notification and tracking number. Thank you for
your patience during this time.
Email or call us for an update anytime.
Thank you,
Customer Support
360-543-5700
Mon-Fri 9am-5pm PST
Thank you,
Customer Support
360-543-5700
Mon-Fri 9am-5pm PST
#67
I see. You checked for 5k, the link I had was for 6k. Is that a big difference in terms of the color?
The bulb in the truck, the connector is perpendicular to the trunk floor, or parallel to the trunk floor?
I just went on VLEDS site and they were out of stock.
OUTPUT RATING: 5
$14.99 Out of stock
OUTPUT RATING: 5
$14.99 Out of stock
#68
Thanks.
Thanks.
This is better 180 degree dome diffuser and will last longer, you can get them from any Autozone for $10/piece. This also work in the trunk and vanity mirror, very bright.
#69
These V-leds will work but they are directional LED flank.
Amazon.com: Sylvania 168/194/2825 Premium White LEDriving Bulb: Automotive
As far as the mirror puddles in the GS,if the VLEDS 4 LED flank is facing down like earlier Lexus models,it works well.
#71
The Sylvania package rate 6000K but it's not, it pure white like V-leds 5K or white just like the GS factory map lights so they all match very well. Give it a try for the trunk first before you pop out the mirror, I had to change the mirror puddle 3 times before stick with Sylvania.
#72
Not sure but the LED flank seem not facing down in the mirror puddle lights for the GS, I got all kind of LED type and only the Sylvania produce useable output and it very bright, more than filament bulbs.
Good to know the whiteness in the Sylvania's are more like 5K than 6K what I prefer.
I'm definitely going with the Sylvania LED in the trunk.I'll probably pick up another pair and use them for the puddles if the 4 LED flanks don't face down.
I've used those VLEDS 4 LED flanks 3-4 times before and they look great in the puddles but all had the flanks did face down.
#73
Base on onexcite recommendation, I got the Sylvania and it worked out perfectly. Brightness and color (matched interior) exactly how I wanted. No hint of blue.
I also tried out the flank bulbs and when the bulbs are locked in the light housing, they are not parallel to the ground. I would say about 20-30 degrees off the horizontal axis. More of the light is directed towards the wheel vs evenly spread directly below the mirror.
Only negative is that they are expensive, $11 for one bulb, $22 for a pair
#74
$22 and they will probably outlast your car. Not too bad I guess. LOL
