DIY puddle light led
#31
Do you think this will work?
#32
I don't think that will fit in the puddle light housing where the bulb goes into.
Something like this is better or best bulb for this
http://item.mobileweb.ebay.com/viewi...d=330755633888
#33
Got these LEDs yesterday from ebay. Quality looks quite good. Once shipped to me will try it out to see which 1 give the best shine
http://www.ebay.ie/itm/ws/eBayISAPI....m=220803151504
http://cgi.ebay.co.uk/ws/eBayISAPI.d...E:L:OU:SG:3160
#34
Flank LED bulbs like these below work best.
The first flanks on this page are great but too long so some altering of the bulb and/or plastic bulb enclosure is needed.
I don't think if the bulb area plasticcover is the same part and size as the ES,tho.
The lens is different and looks smaller.
VLEDs had these bulbs in the shorter version which I've used and others on Club Lexus used with great success.They were absolutely perfect for the puddles.
Since then an heat sink was added making the bulbs a bit too long.
The second set of flank LEDs would fit but I don't know the brightness but they would be white.
http://www.v-leds.com/Shop/Control/f...orLanding/true
#36
The flank style LED will work best if you could get the illuminated side shinning down. BUT you won't because when mount the flank LED on the socket, it will aim to the side of the housing due to the angle of the socket.
#37
Only the last bulb will fit inside the puddle housing. The others are too long or won't aim correctly.
#38
This might work well! Look at the way the LED is positioned...
http://www.aliexpress.com/item/Drop-...628043867.html
#44
