Wheel Spacers quesiton on F-Sport n Non-Sport 4GS
Old 11-13-12, 03:47 PM
xyzstudio
xyzstudio's Avatar
Default Wheel Spacers quesiton on F-Sport n Non-Sport 4GS
since no one start with this thread, i hope someone ( pro) can help us who wanna keep stock rim with better looks by adding wheels spacers
4GS 450H
19x8/19x9 (stock) : F ? mm R ? mm
18x8 (Stock) : F ? mm R ? mm
4GS 350 F
19x8/19x9 (stock) : F 19 mm R 25 mm
Completed
4GS 350 ( non-f)
19x8/18x9 (stock) : F ? mm R ? mm
17x7.5 (stock) : F ? mm R ? mm
thanks in advanced
front 19mm about 1" lowered and rear 25mm 1" lowered.
Old 11-13-12, 07:37 PM
Nexson
Nexson's Avatar
I will be eventually getting the fsport springs and OEM adapter spacers. I will most likely go with something like 15 front and 20 rear.
I want to keep this car OEM but with subtle mods.
Old 11-14-12, 08:48 PM
HizGSF
HizGSF's Avatar
I a set of 20mm Hub centric spacer in rear which pushes the wheels out almost flush with the fenders.
In the front I currently do not have any spacers. A set of 10 or 15mm spacers will probably set it flush.
The car has been lowered 1.75 front and 1.5 rear and no rubbing.
Old 11-14-12, 08:50 PM
bentleymp2
bentleymp2's Avatar
How did you lower your car?
Old 11-14-12, 11:48 PM
xyzstudio
xyzstudio's Avatar
Thumbs up
thanks for the input, btw can u post some closed up pic for rear ? (different angles ! ) also what brand of wheel spacers u use ? and stock 19" wheels ?
thanks in advanced
Old 11-15-12, 04:11 AM
Nexson
Nexson's Avatar
Please post pics!!
Old 11-15-12, 09:26 PM
HizGSF
HizGSF's Avatar
I purchased custom springs from a company down in Florida. Other CL members has the same spring setup like, djpeakSD. I am very happy with it and rides like the stock springs
The front dropped 1.75 and rear 1.5 inches.
Old 11-15-12, 09:31 PM
HizGSF
HizGSF's Avatar
thanks in advanced
I purchased ICHEBA hub centric spacers, 60.1mm Hub, and 5X114.3 bolt pattern.
I'll take some pics and post them.
Old 11-16-12, 08:52 PM
HizGSF
HizGSF's Avatar
Shot of the rear wheel with 20mm spacers.
Attached Thumbnails Wheel Spacers quesiton on F-Sport n Non-Sport 4GS-img_0437.jpg   Wheel Spacers quesiton on F-Sport n Non-Sport 4GS-img_0422.jpg
Old 11-17-12, 01:29 PM
xyzstudio
xyzstudio's Avatar
great pic,very nice with 20mm u have on the rear , thanks im gonna order mine today, btw do u think 15mm all around will do it? since not much difference from 20 n 15 ?
Old 11-17-12, 03:21 PM
Outrage
Outrage's Avatar
I would think that moving the wheel's mass away from the centerline of the vehicle would cause higher loads to be placed on the springs. The effect would be similar to using softer springs. Also, the suspension's geometry under load would be modified. Typically, a specific amount of negative camber, under load, is designed in to the suspension's geometry in order to maintain an ideal tire contact patch. Changes to the wheel's relative position could lead to inferior handling characteristics and increased tire wear.
Old 12-01-12, 12:56 PM
xyzstudio
xyzstudio's Avatar
finally, i have installed 19mm all around on my 4GS F, and i believe , the rear needs another 5mm, so im gonna order another set 25mm for my rear, will update pix once its installed.
Old 12-01-12, 06:01 PM
Nexson
Nexson's Avatar
I am going to be going this route as this is all the car needs. Once the f sport springs are released it will be pair well with 25mm rear spacers and 20mm front.
Old 12-01-12, 11:17 PM
Maseroche
Maseroche's Avatar
It doesn't rub with the 19mm in the front? I was thinking of going for 15mm all around like your original plan.
Old 12-06-12, 12:26 PM
xyzstudio
xyzstudio's Avatar
19mm all around installed
Quick Reply: Wheel Spacers quesiton on F-Sport n Non-Sport 4GS
