GS450h / GS350 reverse ligths
Old 08-08-12, 11:51 PM
hube
hube's Avatar
Default GS450h / GS350 reverse ligths
I noticed there is a difference in rear light setup on the GS. There seem to be versions that have two reverse lights. Where here in Europe all seem to have a single reverse on the right and a fog light on the location where you'd expect the second reverse light.
So if this is a difference with the US model and the EU, where are the rear fog lights located in the US model? The reflectors in the rear bumper?
Here is a pic of the one reverse and fog light setup modeL (look specifically at the left units)
And here the dual reverse light version:
Obviously I am asking this for potential future modding of the single reverse light version.
Thanks all.
Old 08-09-12, 12:29 AM
rominl
exclusive matchup
rominl's Avatar
i don't think US spec cars have rear fogs at all
Old 08-09-12, 01:29 AM
hube
hube's Avatar
That explains a lot. Thanks!
Old 08-09-12, 06:26 AM
kyo7878
kyo7878's Avatar
rear fog seems to be in led?
Old 08-10-12, 12:09 PM
Blackraven
Blackraven's Avatar
Apparently, in places like Japan, the Americas (from North, Central and South) as well as Australia + New Zealand, you get both reverse lights for the 4GS.
However, for other countries/territories like Europe and parts of Asia, we're pretty much screwed on this.
I call this kind of setup as the "ASYMMETRIC BUTT"
Sadly, there some cars out there that sadly follow this setup:
*NOTE: In Europe, Honda Accord only has one reverse light + rear fog lamp. In Japan, Australia, New Zealand and the Americas (as the TSX), the vehicle has two reverse lamps*
Now, in the case of Lexus, this may just be speculation but I'm guessing this was brought about by cost-cutting (perhaps due to the unfavorable Japanese yen exchange rate).
Anyways, if I were to get a GS here (our 4th gen GS units here also have this ASYMMETRIC setup), I would buy a left hand side reverse lamp module, swap the rear fog lamp and assembly out................then sell the rear fog lamp module for probably 5 bucks on Ebay
Problem solved (for me)
Old 08-10-12, 01:33 PM
onexcite
onexcite's Avatar
Anyone trying these on yet: 15w HID reverse light.
http://www.ebay.com/itm/15W-Reverse-...ht_1350wt_1159
Old 08-10-12, 02:47 PM
iJDMTOY
Former Sponsor
iJDMTOY's Avatar
HID reverse lights are definitely bright, but having them on too long may create a lot of heat that the housing cant' take. Plus, you have to wait about 3-5 seconds in reverse until the lights fully warm up before you can fully use it.
I recommend LED bulbs instead:
http://store.ijdmtoy.com/Plasma-High...tm&click=35328
Old 08-10-12, 10:07 PM
*Batman*
*Batman*'s Avatar
This is weird. A car if this caliber should have 2 reverse lights in all markets, and European models should have fog lights too.
One thing I learned that was interesting when I bought my BMW is that even the US spec cars have rear fogs. They just don't have a fog switch on the instrument cluster. However I ordered the switch from Europe, swapped it with the US spec switch, and hey presto my rear fogs could be turned on. It makes a ton of sense to have just one global part.
Old 08-11-12, 12:00 AM
yamanote
yamanote's Avatar
The 3GS in some markets had different tails too, like my HK/AU spec 450h.
Different to the 4GS obviously, as the rear fogs didn't replace the reverse lights, just the inner LED running strips.
Old 08-11-12, 03:29 AM
hube
hube's Avatar
I am sure the aftermarket will come up with something. But symmetry is something I find quite important on cars. Not having rear fog lights is not an option since the rear fog light(s) are mandatory here.
Thanks for all your answers.
Old 08-13-12, 11:37 AM
Blackraven
Blackraven's Avatar
If you need to buy a 4GS that badly, you could probably replace the LED fog light strip with a reverse lamp module.
Then just install aftermarket rear fog lamps somewhere else. (just hope that this won't void warranty).
Either that, or check if the Lexus LS (for Europe) will have two reverse lights and two rear fog lights.
Otherwise, if all else fails, then I guess you'd have to stick with your 2IS a little longer (or if you really need a new car that badly, then I'm afraid that you would have to look outside of Lexus for that).
Old 08-14-12, 11:59 AM
Alantjai
Alantjai's Avatar
you might be able to just swap the inner driver side taillight unit :P
cubu
GX - 2nd Gen (2010-2023)
38
04-12-23 03:56 AM
bjhegstad
NX - 1st Gen (2015-2021)
04-15-16 11:01 AM
14blk250a
11-25-14 04:21 PM
eddo1
09-25-06 02:17 AM
jlin101
12-31-05 01:19 PM
Quick Reply: GS450h / GS350 reverse ligths
