GS F-Sport Fog light upgrade kit??
#77
http://nigel-jdmparts.com/2013-gs350...-light-housing
#78
Yes, option is 5 included all the hardware and you need to do the wiring.
#82
Finally ;-)
Hi All,
Finally, i got my Fog light installed on 2013 GS350 F-Sport. Very happy with the result.
I'm using
1. MORIMOTO XB LED FOGS (TYPE T)
2. http://www.ebay.com/itm/131349802011?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT3. http://www.ebay.com/itm/381061322004?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT4. a set a F Sport bezel cover from Nigel_JDM
Note: I have my audio guys hooked up the remote cable for the Fog with my amp remote signal. So, my fog light will turn off when the car turn off.
Let me know what you guys think.
Thanks
Next: mod: maybe paint the calipers. Yellow??? ;-)
I'm using
Thanks
#84
Hi All,
I'm using
2. Universal harness
3. H11 connector
Thanks
I'm using
3. H11 connector
Thanks
#85
Great looking. I like to get this done on my 2015 GS350 F Sport. Do you think it would be compatible? When I checked ebay for compatibility it says not compatible. Also, did you get Option1 (just the bezel) from Nigel? Other than these 4 parts you listed is there anything else required?
I got option 1 from Nigel which only the bezel. (shipping took over a week)
Not sure on 15 GSF tho. But you can ask Nigel to see if those bezel will fit your ride.
As for my setup:
Get all the things listed above and you will be fine.
As for screw... well... u needs 4 screws total. 2 each Fog light... and both are on the bottom bracket. Note: the screw hole to mount the fog is not puncher. So, dont be alarm when you screw it in. Its will puncher threw the front a bit but the bezel will cover it. I use 3/4" long screw.
Another thing: The harness kit i bought the wiring a bit short. So, i extended both fog light wires for another maybe 7".
I hope this help.
#86
Hi,
As for my setup:
I hope this help.
As for my setup:
I hope this help.
#87
#89
