2007 GS 350 front lights headache! HELP!
Hi, I am having problems with a 2007 GS 350 I recently purchased, the complete passenger side lights are not working (Runing lights, low beam, high beam and fog lights) and the AFS OFF light is blinking, not sure if its that the sensor is faulty or its because of the same lights problem.
So far this is what I have done,
Under the hood on the driver side there is a Fuse and relay box which I opened and found one 15A fuse almost destroyed in, it was located on HLP R LWR here is what the fuse looked like when found:
I replaced it with a new fuse but still nothing works, i tried to pull the fuse below that one that is for the left headlight (Driver side) and it turns off the low beam which only not the complete side.
I tried switching bulbs and bulbs are not the problem, any ideas what could be? That fuse being melted gives me a bad vibe, you guys think it could be the complete line fried?
Thanks in advance
Thanks in advance
Does the blinker work on the right headlight? And when you turn on the headlights, do the parking lights come on?
Having the wiring diagrams for the headlight system would probably be the best way to track down any other fuses/relays that could cause the problem. You can get them (and all the other repair manual documents) at techinfo.toyota.com
Nothing works on the front passenger side not even the blinkers
PaulyGS300 (10-08-19)
T.K.O.
12-04-06 10:22 PM
