Replaced headlights found this
Old 02-03-17, 03:22 PM
diesel916
diesel916's Avatar
Default Replaced headlights found this
Had some after market bulbs in GS350 that would always turn off at night, I would turn the lights off for a couple seconds and then turn them back on and they would work for a couple minutes and randomly turn off again. Both side but mainly the driver side more often.
Finally got around to buying new bulbs and when replacing them I noticed a considerable amount of corrosion on the driver side more in the piece that plugs in to the back of the bulb not sure what that is called. I really only noticed it because the piece didn't not want to go into the new bulb there was so much build up I had to clear it away with a screw driver and ended up removing some of the rubber that goes around it(ooooppps) but I got it to go back on, both lights are working now, but I feel like the driver side bulb is dimmer. it is day time but I can barely see the light on the fence in front of me while I can clearly see the passenger side light on the fence. Is this a cause for concern? What do I do? Thanks for any help!!!
Old 02-06-17, 01:35 PM
rl9010
rl9010's Avatar
You can replace the HID ballast. That will give you a new connector.
https://www.clublexus.com/forums/gs-...f-ballast.html
diesel916 (02-09-17)
AlFakher
10-01-12 05:37 AM
JoeCombs
08-14-10 11:43 PM
TOP GUN TT
SC- 1st Gen (1992-2000)
10-15-08 05:29 PM
GXLUV
GX - 1st Gen (2004-2009)
14
04-30-06 04:47 PM
BlkOnBlkGS
Lighting
11-27-05 12:04 PM
Quick Reply: Replaced headlights found this
