2006 gs300 fuel injectors replacement.
Old 01-12-17, 10:20 AM
aristo1987
aristo1987's Avatar
Default 2006 gs300 fuel injectors replacement.
Anybody here ever change it? Any vid or write ups on how to do it?
Where are the fuel injectors located on a 2006 gs300? I wasn't able to locate it lol...please advise much appreciated.
Pics n arrows would help a lot
Old 01-12-17, 04:48 PM
Sodium
Sodium's Avatar
You can get the replacement procedure from the Lexus repair manual at techinfo.toyota.com. You'll have to create an account and pay $15 for two day access, but it's worth it in this case since injector replacement isn't the kind of thing where it's fine if you get it wrong the first time
Othic
Othic's Avatar
You need a special tool to install fuel injector o rings. I would not recommend you do this. Why are you replacing them?
Old 01-12-17, 08:49 PM
SILENTM
SILENTM's Avatar
Also they are colored coded for calibration so you will need to see what color band you have ( black or brown) they are under the intake manifold in between the engine block valley. As Othic mentioned you need special tool to insert the 2 teflon seals on the tip. Also the connector is fragile and may break
Being that its a 2006 you may have a lot of carbon build up and may want take care of that at the same time
Old 01-13-17, 03:10 AM
aristo1987
aristo1987's Avatar
Thanks for all the info guys much appreciated!
As for tools i have every single tools that was ever made for any vehicles lol
kayizm007
01-30-16 11:06 PM
saleen90
09-02-13 06:31 AM
haileye
SC- 1st Gen (1992-2000)
09-15-10 06:03 PM
rsxtc
10-29-07 04:43 PM
Quick Reply: 2006 gs300 fuel injectors replacement.
