No Start
Old 01-05-17, 05:46 AM
RXGS
RXGS's Avatar
Default No Start
So the other day my 2006 GS300 didn't start, I chalked it up to being a dirty terminal since there was corrosion all around the positive terminal, so I cleaned t and it started right away. The day after, the same thing happened, no start, no clicking noise, so I jump it and it starts 2 more times. The third time again, no start, no clicking, but the lights work fine.
Its at the dealer now after getting the battery tested with the drain charge being suspect despite it only being 2 years old, but what worries me is the intermittent start and the no clicking leading me to believe it's the starter. How common is this because the service advisor said it isn't a common issue. If the starter were going bad, wouldn't the times it started be rougher than usual? Any input would be great thanks
Old 01-05-17, 06:19 AM
RXGS
RXGS's Avatar
Got a call from the dealer, unfortunately I was right and it is the starter. Quoted $850 for a Lexus starter and $630 for aftermarket so I'm going that route.
Old 01-05-17, 11:03 AM
Sodium
Sodium's Avatar
Be careful with those aftermarket parts! I replaced my original water pump last February (failed around 90,000 miles/8 years) with an aftermarket one from Oreilly's, and about two hours ago I took delivery of a Lexus water pump to replace the aftermarket one (started leaking out of the weep hole after about 17,000 miles/10 months).
Old 01-05-17, 11:49 AM
RXGS
RXGS's Avatar
The dealer is doing it and has a warranty on it so it's their problem if it goes bad ha, it's a denso so it should be ok
Old 01-05-17, 12:09 PM
TRD_Power
TRD_Power's Avatar
Denso stuff usually lasts, so I wouldn't worry too much. My starter has been giving me intermittent issues since 20k, but it's been a while since, so keeping my fingers crossed.
Old 01-05-17, 04:22 PM
RXGS
RXGS's Avatar
I drive about 2-3k a month so I didn't want to take a chance, also got an RC for a loaner for 3 days so I'm ok with it
Old 01-05-17, 05:01 PM
Htony
Htony's Avatar
Rebuilt ones are good but after market? Who knows where it is made?
Old 01-05-17, 07:38 PM
Sodium
Sodium's Avatar
Ah I see. Yeah in that case both starters probably came off the same assembly line, the only difference being that one of the factory workers then wrote "Lexus" on one of them in crayon so that the dealer could charge 35% more
Old 01-05-17, 08:19 PM
ibidu1
ibidu1's Avatar
Buy a used starter! I checked on car-parts.com for a starter in your area and the starters from 06-2014 IS350 are the same and for $50 bucks for a 2014 is imo better then buying a aftermarket or a rebuilt
Old 01-05-17, 08:22 PM
RXGS
RXGS's Avatar
I already paid the $630, not ideal but really not a lot to ensure the vehicle runs ha
kaban1993
Performance & Maintenance
07-17-20 06:48 AM
Boosted78
08-03-11 05:20 PM
powrserj
11-15-07 07:06 PM
demon1
06-29-07 06:08 AM
valgs350
08-10-06 10:32 AM
Quick Reply: No Start
